You retrofit NPP to your car and need an Exhaust Controller?Exhaust Commander is HERE
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
The ULTIMATE NPP / Z06 Exhaust Commanderis HERE, Click Here to go to the WEBSITE!
This is the FIRST RPM Adjustable Wireless Exhaust Switch. It lets users who want to retrofit Bi-Mode Exhaust to a C6 that didnt come with it from the factory complete the task easily. It also allows C6's that have bi-mode already to control their exhaust exactly how they want.
You can use the GM Vacuum piping, vacuum solenoid and parts, plus this innovative controller to get full 3 mode operation of a retrofittted Bi-mode system.
Or, you can combine this innovative controller with a 12 volt vacuum pump and get a functioning All-in-One bi-mode system without having to run the GM vacuum lines.
If the demand is there for an ALL-in-One kit that doesnt need gm vacuum lines and is a one step process to get it up and running solution, I can have that up and running in no time at all.
Pm me if that is the route you want to go.
The ULTIMATE NPP / Z06 Exhaust Commander is the First RPM adjustable Bi-Mode exhaust controller for the Corvette C6 and C6 Z06.
With the ULTIMATE NPP / Z06 Exhaust Commander kit, you take full Command of your Bi-Mode exhaust system by choosing what RPM the butterfly valves open at, as well as the ability to choose a Full Open mode.
You select between Full Open mode and Stock Rpm Open Mode and Lower RPM Opening mode via the supplied wireless remotes.
You select the RPM at which the muffler butterflies open by setting the dip switches on the RPM Command unit.
YOU take Full Command of Your Bi-Mode Exhaust!
Do you want the muffler butterfly valves to open at 1800 RPM so that the mufflers remain open the longest time possible, while eliminating the "Drone Zone" Rpms? NPP / Z06 Exhaust Commander is for YOU!
Do you want the butterfly valves to open just a little sooner? Set the NPP / Z06 Exhaust Commander to open at 2600 RPM's. You decide when you want the butterfly valves to open, not GM's engineers!
With the ULTIMATE NPP / Z06 Exhaust Commander, You select the RPM at which the butterfly valves open. The RPM choices at which the valves open are: 1800, 2000, 2200, 2400, 2600, 2800, 3000, and 3200 RPM on the standard unit. (Custom Rpm settings are available)
You also can choose the Full Open mode for those times where you want it Loud all the time! And can switch back on forth between the three modes instantly with the wireless remote.
The ULTIMATE NPP / Z06 Exhaust Commander will NOT Drain your battery when the car is Off.
This Product works on any 08 NPP Bi-Mode Exhaust system or Z06 Bi-Mode Exhaust system.
It also gives full control to C6 cars that have retrofitted the NPP / Z06 Mufflers and want a RPM opening mode!
It allows users who have retrofitted Z06 or NPP mufflers to a C6 to have a user selectable RPM opening mode, as well as the Full Open mode. Thus making the retrofitted system work similarly to a Factory system, only Better as the user Commands the valves to open at the user selected RPM. The retrofittted systems do need to have the vacuum control solenoid in place for the NPP / Z06 Exhaust Commander to have the ability to control the Butterfly Valves.
ULTIMATE NPP / Z06 Exhaust Commander uses the Tachometer signal and a RPM control unit to tell the Butterfly Valves to open.
Full, Detailed Installation instructions with pictures included.
Why let Gm's engineers control your exhaust?
Order yourself a ULTIMATE NPP / Z06 Exhaust Commander and take Full Command of your Exhaust Today !
Feel Free to drop me a PM with any questions you may have!
St. Jude Donor '13
PM me if you need any info on the retrofit process.
St. Jude Donor '13
TTT for those that are looking for a wireless NPP / Z06 exhaust controller that does rpm open, as well as full open and full closed for a retrofit NPP System.
With this unit you can control the NPP Mufflers and make them operate just like a car that came with NPP from the Factory.
Only Better! You choose the rpm at which they open, as well as full open and full closed all from One Wireless Remote!
Use either the GM vacuum piping or a miniature 12 volt vacuum pump to supply the vacuum to the butterflies.
Feel free to let me know if you need any info.
