vert owners trunk lid question
I picked up my 08 vert in early sept, I cannot believe how much pressure it takes to close the trunk lid, it seems I should know some type of martial art to drive my hand down to close the lid, if you just try and close it like I did on my C5 the sides don't latch, and you have to pop the lid and do it again, does anyone else notice this ? it is kind of like forcing the lid down with the trunk stuffed full even when it is empty the trunk lid pops open the same way , what do you think
Dan
Dan
My 07 is not difficult to close. Sounds like the two rubber bumpers may be adjusted out too far, have you tried to run them in a bit? When closing mine I lower it then give a small push and down it goes.
I am not sure what you mean about the sides latching.
Hope this helps.
Hope this helps.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
yes, mine reqs some effort. and unless really banged shut, it doesn't.
Like, I'll have to go look for/at those rubber bumpers and see how they move in. thanks for the tip!!!
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,435 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Cruise-In VIII Veteran
Dan
Dan
FWIW, I'm also planning on having a ~4" 1/2-moon-shaped piece of 3M clear film placed over the latch when I get the rest of the car done.
The rubber bumpers are definitely set too high if the corners are not flush with the fenders with the deck lid latched. The only purpose for the bumpers is to set the proper height of the deck lid at the corners. If the corners are perfectly level with the fenders when the deck lid is finally latched, then your center latch needs adjustment.
St. Jude Donor '15
"In honor of jpee"
Thanks for the tip on how to get them to move!
Be gentle.
Try lowering the hatch easy to the point of just touching resistance. Then apply gentle pressure until the mechanism graps. Continue gentle pressure until pull down starts, then release and let close itself. See also the manual.
I talked to Bowling Green about this when the car was new. They said to check the allignment and clearance of the hatch, but it turned out to be ok.
St. Jude Donor '15
"In honor of jpee"
