Post your BONE STOCK LS3 dyno numbers...
Old 11-30-2007, 06:39 PM
  #81
11secondGP
11secondGP's Avatar
To be fair, you should at least deduct 15 hp
Still happy with 38Xwhp on an auto though...
11secondGP is offline
Old 01-09-2008, 09:10 PM
  #82
Boomer111
Boomer111's Avatar
LS3, 475 miles, 6 sp. No modes bone stock base model.
Test done on a Dynapack Chassis Dynaometer.
Base run and tune run on 91 octane.
375.8 rwhp.....383.0 lbft
after tune
398.1 rwhp.....407.1 lbft
Correction method SAE
22.3 rwhp gain and 24.2 lbft gain
AFR was low 11's. After tune 12.4.
Performed at Synergy Motorsports
Thanks Rick
Boomer111 is offline
Old 01-13-2008, 05:49 PM
  #83
Tom Steele
Tom Steele's Avatar
Originally Posted by JSB LS3
the '02 Z28 for example, was rated at 310 flywheel HP, yet there are more than a few cases of stock LS1 cars making 320 REAR WHEEL horsepower.
It had a VERY efficient driveline.
Tom Steele is offline
Old 01-13-2008, 11:45 PM
  #84
SpryGeezer
SpryGeezer's Avatar
Why bother?
SpryGeezer is offline
Old 01-14-2008, 07:36 AM
  #85
1.8t
1.8t's Avatar
385whp/378wtq SAE. I do NOT have the NPP option. Dyno was done w/ 1300 miles on the odometer.
1.8t is offline
Old 08-15-2008, 01:10 PM
  #86
harddrivin1le
harddrivin1le's Avatar
Originally Posted by C6 DVL
the engine is very underrated.........I guess they didnt want the HP to close to the Z06
The LS3 is not "underrated" by any means.
It is precisely rated because it is SAE CERTIFIED HP. Production engine output must consistently be within 1% of the advertised figure in order to obtain and retain the Certified rating.
http://www.caranddriver.com/features...olution_column
People who think that a fixed percentage (e.g. 17%) can be applied to somehow "convert" drive-wheel HP to flywheel HP don't understand the complexity of the subject. This is one of several good articles I've seen on the subject. As you can see, high HP cars can "lose" less than 10% from the flywheel to the dyno rollers.
The NPP LS3 is rated @ 436 HP. 10% of that is 43.6 HP. 436 - 43.6 = 392.4 HP, which is at the high end of what stock LS3 NPP cars are recording.
http://www.sportcompactcarweb.com/pr...t_4/index.html
"Horsepower Hype--Separating Fact from Fiction
Converting rear-wheel power figures to crank numbers is anything but straight-forward. When translating wheel figures to engine claims, some experts use fixed conversion factors. That is, if a stock 218 rear-wheel hp RX-7 is rated from the factory at 255 crank hp, it must have 17-percent driveline losses. A 284 rear-wheel hp RX-7, then, must be blessed with 332 crank hp. This popular, if somewhat optimistic, correction technique assumes driveline loss is proportionate with engine output. That is, as wheel horsepower increases, driveline loss must also increase commensurably. Some would even disregard stock quotes and apply a standard 20-percent drivetrain loss figure. Using this popular correction factor, we already have a 340-hp monster! Some would vehemently disagree. These folks would tend to use a fixed number to represent driveline loss. In this case, they would believe that all RX-7s are faced with a driveline loss of 37 hp. (255 minus 218). Using this correction method, Project RX-7 produces a more conservative 321 ponies at the crank. All three techniques, (as well as other far more [Ahem.] optimistic methods) have been used at one time or another.
Our friend at Superior Dyno Service, Keith Paulsen, looks at this issue from another perspective. "The first mistake people make is assuming that factory-quoted horsepower figures are accurate," Paulsen states. "Due to marketing hype and year-to-year tuning changes, it's not always accurate to derive drivetrain loss by comparing measured wheel horsepower and factory quotes."
Paulsen also believes that drivetrain losses are neither an absolute percentage nor a fixed number. Instead, he feels the crank-to-wheel relationship is far more beguiling. From his considerable experience, Paulsen suggests that low horsepower (100-200 hp) cars may suffer from as much as 15 to 20 percent of drivetrain loss at the rear wheels. For more powerful cars (200-400 hp), the figure is around 12 to 15 percent. And for mega-powered cars (above 400 hp), the drivetrain losses can reduce to 10 percent or less. What's going on? Getting into the physics behind this complex relationship is worthy of a project in itself. (Engineering editor, Dave Coleman says he's working on it.) For the scope of our project, let's take Paulsen's advice and only compare apples to apples. In our case, our apple is rear-wheel horsepower. So be it. Readers should also note that we made sure that at no time were race fuel, tweaked ignition maps, chilled intercooler, or wastegate trickery used during our dyno testing. We tested our daily driver, not a one-off test mule. Notable was the fact that the five consecutive runs, separated by five minute "cool down" periods, yielded variances of only 1 to 2 hp.
harddrivin1le is offline
Old 08-15-2008, 03:54 PM
  #87
Pocket Aces
Pocket Aces's Avatar
Originally Posted by SpryGeezer
Why bother?
What the hell is wrong with the viper engine at 3600? Must have sampled right at gear change or something.
Pocket Aces is offline
Old 08-15-2008, 04:04 PM
  #88
RRVettes
Support Corvetteforum!
RRVettes's Avatar
Originally Posted by talon90
I call
No way you got that kind of number out of thing 2 bone stock.
RRVettes is offline
Old 08-09-2009, 03:40 AM
  #89
Insom
Insom's Avatar
389rwhp / 372torq out of an '09 LS3 with 70 miles on it.
103 intake temp.
Insom is offline
Old 08-09-2009, 03:51 AM
  #90
bapd77
bapd77's Avatar
Originally Posted by '06 Quicksilver Z06
There is no more underrating or overrating. The LS3 like the LS7 horsepower rating is SAE certified. Meaning that GM is guaranteeing that all the engines of each type, be they LS3 or LS7, will dyno within 1% of one another. There are no ringers, strong ones, weak ones or underrated ones.
While the links below refer to the LS7, they can also be extrapolated to the LS3 because both are SAE certified.
http://forums.corvetteforum.com/show...post1562787163
http://forums.corvetteforum.com/show...&postcount=356
http://forums.corvetteforum.com/show...&postcount=371
If its SAE certified, it pretty much is what it is.
I was unaware of the SAE certification and differences in horsepower measurements.
Question: Does anyone know what the LS2 horsepower rating is based on the new horsepower "certification"?
bapd77 is offline
Old 08-09-2009, 05:37 AM
  #91
LTC Z06
Get Some!
LTC Z06's Avatar
Originally Posted by 03 Z-oh-6
The lowest so far 366 while the highest is 392!!! I realize the NPP may add a few horses. I know there's a lot of factors involved, but 28rwhp is a big variance!!!
That's dynos for you.
LTC Z06 is offline
Old 08-09-2009, 05:42 AM
  #92
LTC Z06
Get Some!
LTC Z06's Avatar
As far as I know we don't but as discussed in another thread and on the SAE website, some engines went up in HP and some went down.
LTC Z06 is offline
Old 08-09-2009, 10:28 AM
  #93
Tact
Law Dawg Moderator
Tact's Avatar
CF St. Jude Co-Organizer
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Existing threads receiving no replies for 45 days or more.
If an existing thread has not received a reply for a period of 45 days or more, members should create a new thread which is identical or similar in nature, rather than to post to the existing one.
Similar or identical threads created under 45 days will be considered a dupe, and will be locked accordingly.
Members shall not post to such threads as a means to resurrect them for discussion or as a means to be humorous.
This rule will not apply to technical discussions or to posts in threads where such posts have been made to update the threads with information deemed by moderators to be of benefit to Forum members.
Tact is offline
Quick Reply: Post your BONE STOCK LS3 dyno numbers...
