Old 02-23-2015, 03:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Browse all: Engine and Powertrain
Print Wikipost
Stock muffler mod...
Old 06-18-2008, 01:29 PM
BetterMostC6
BetterMostC6's Avatar
Just drill a hole in the bottom and pull some packing out. Use muffler tape or bondo or even a rubber plug to cover the hole.
CorvetteBrent (11-20-2019)
Old 06-18-2008, 01:43 PM
glennhl
glennhl's Avatar
How about a poor man's NPP? On the sectioned muffler, I'm assuming the inlet is on the top right and the outlet is on the bottom left. If I'm wrong, please correct me.
So why not punch a hole in the back chamber of the muffler and either weld in a manual cutout or if you want use an electric cutout? Wouldn't you then have a pretty straight shot through the muffler. Does anyone have a cross section of the NPP muffler?
Spaz1 (12-22-2020)
Old 06-18-2008, 01:57 PM
gimmie_one
gimmie_one's Avatar
Location: OC California ------- A rich man's joke is always funny.
Originally Posted by theVcar
What about tips? Does the $200 cover the weld for the tip replacement. I thought the better way to go was the Flowmaster 17427 for $375 + install.
I have heard that the flowmaster is more restrictive than the magnaflow. The flowmaster is also somewhat louder. Someone correct me if I'm wrong as I'm no expert on the subject.
Old 06-18-2008, 02:10 PM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
In the good old days we used to drive for 30 - 45 mins to get the exhaust sys. plenty hot, and then squirt cold water into the mufflers to fracture the fiberglass. It made a noticeable difference and it's cheap to try.
Old 06-18-2008, 02:30 PM
From C6ZO62C8
From C6ZO62C8's Avatar
Originally Posted by talon90
Here's what the inside of the stock muffler looks like. This will give you a target to aim for.
nice, that looks restrictive, I'm suprised that with an exhaust swap you only get about 8 HP, after seeing this I would think that you would get more.
thanx for the pics
Old 06-18-2008, 02:32 PM
talon90
Support Corvetteforum!
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Originally Posted by CraigE
My 07 C6 has a 10 amp fuse at the bottom right of the passenger footwell that says exh.
I don't think it does anything though.
I think they use the same fuse boxes on the Z06 ,which would use the fuse.
One less thing to keep track of at the plant.
That is correct. That is the Z06 butterfly control fuse.
Old 06-18-2008, 03:45 PM
VET4LES
VET4LES's Avatar
In the old days fiberglass mufflers got louder as they got older and the fiberglass deteriorated. Has fiberglass improved or maybe the stock system will get louder with time?
Old 06-18-2008, 03:59 PM
trivette
trivette's Avatar
I wonder about the 'louder with time' theory also. I know my '84 that is totally original with 19,000 miles is definitely louder than when new. Most of the miles on it have been highway which may contribute to 'blowing out' some of the system. I don't really know what the '84 muffler is composed of internally-baffles w/fiberglass or? My '05 with 10,000 doesn't seem any louder than new despite probably 6,000 of them logged on trips plus a number of autocrosses. I keep contemplating doing something to improve the sound but am too cheap to do an entire system when there is for the most part a negligible HP gain to be had from it. If anyone experiments and has results from the drilling/removal of 'glass material it would be good to hear their comments.
Old 06-18-2008, 04:43 PM
glennhl
glennhl's Avatar
I think my 06 has gotten louder. Not only that, but I notice a drone at 1500 rpm (A6) if I'm going up a slight grade. I never noticed that before.
So does anyone have a cutaway of the NPP. I'm getting very interested in my proposed mod of cutting a hole in the back chamber. I think you can do the NPP mod for a couple of hundred dollars instead of $1200.
Old 06-18-2008, 05:36 PM
VET4LES
VET4LES's Avatar
I hope your right, keep us posted.
Old 06-18-2008, 07:41 PM
mracer
mracer's Avatar
I would bet if anyone were to muck around with the stock muffler's, like taking strands of fiberglass out, the Drone Monster would rear it's ugly head? Look how many here on the forum pay good money for aftermarket exhausts, only to put them up for sale after driving with them for awhile?! Why, feedback on drone, and some too loud to.
ymmv
Mike
PS: But I'd still like to see someone do it.................
Richard G. (03-05-2022)
Old 06-18-2008, 07:55 PM
cclive
cclive's Avatar
I've heard a number of people say that the car is slightly louder than it was to begin with, but not many cars on here ever get enough miles for this to matter. I think its probably more miles than time that matters...
Old 06-19-2008, 03:49 PM
  #33
dkrhardy
dkrhardy's Avatar
I did the exact swap that Ozone did, and I will tell you that the Magnaflow's do get louder!
Old 06-19-2008, 04:34 PM
  #34
F40
F40's Avatar
npp mod for $200? I would like to hear more on this
Old 06-19-2008, 05:00 PM
  #35
ufaj26
ufaj26's Avatar
This is true. I have almost 17k on my 08 and it is some louder. But just a little more noticeable. It won't get much louder overall
Old 06-19-2008, 07:56 PM
  #36
cclive
cclive's Avatar
And on this forum, 17K on an '08 puts you far out at the end of the annual mileage curve!
Old 06-19-2008, 08:16 PM
  #37
BigJoe
BigJoe's Avatar
Gad, no kidding. I just turned 22,000 on my 2005 and I don't notice it being any louder than the first day I drove it.
To Stock muffler mod...
Old 06-19-2008, 08:52 PM
  #38
sd455ta
sd455ta's Avatar
Does anyone know who make the Corvette mufflers?
It most likely is one of the big manufacturers.
Why not sent that cutaway pic to their engineering department and ask them what can be done to improve the exhaust sound.
Or better yet sent it to Ferarri exhaust engineers for some ideas.
If that does not work, someone with a welding outfit could, peel back part of one or both sides, open up some larger holes in the perforated tube section, remover some filler and weld it up again. Very cheap and easy to do.
I think their would be lots of interest in a simple, inexpensive muffler modification to improve the sound level, while maintaining the stock system!
Any sheet metal hobby guys out there?
Rich
PS: I do not have a welding outfit or I would do it myself!
Old 06-19-2008, 09:49 PM
  #39
glennhl
glennhl's Avatar
Walker make the OEM mufflers.
Rich
Old 06-19-2008, 11:32 PM
  #40
Weely
Weely's Avatar
Is the pipe at the top of the photo where the exhaust gas goes into the muffler or goes out of the muffler?
Quick Reply: Stock muffler mod...
