Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Browse all: Engine and Powertrain
- Exhaust Modifications
Overview of popular modifications to customize your Corvette
- Muffler Modifications
Reviews and comparisons of top products
Stock muffler mod...
#41
I know what you're thinking...did he fire six shots? Or only five?
The pipe on top is the exit pipe. The curved pipe is the entry pipe. So, putting a cap or dump at the end of that straight pipe won't provide a straight through exit for the exhaust gas (a la Warlock mufflers). I have a set of factory mufflers sitting around and with this cutout pic, I may play around with installing a "tap" to the entry pipe to provide an exit before the gases reach the curved pipe.
The problem is, there is little clearance between the top of the muffler and the rear bumper (ie above the dual exit tips) where the ideal spot for a cutout would be.
#42
Le Mans Master<br><img src="/forums/images/ranks/5k-6k.gif" border="0">
St. Jude Donor '08-'09
#44
Received 2,061 Likes
#45
I would have to agree with you. That is without a doubt the hangar so that would confirm that the curved pipe is the exit based on the way the system mounts to the car.
#46
Photo taken from inlet side (same as upper right in cutaway) shows the embossed stiffener (upper left in cutaway). Obviously an impossibility from the outlet end.
The bright flecks are metal particles from sawing off the inlet pipe.
I installed Z06 mufflers and chose to keep the 2 1/2" pipe.
#47
Maybe a pic of the inside of a Flowmaster or other muffler would help us come up with some ideas....it looks to me like the inside ends of both pipes are just open and so its not immediately obvious how to make this muffler a little louder...or deeper or whatever...
#48
That actually makes tapping the inlet easier to put in a straight through cutout...except for the clearance problem I mentioned earlier
#51
I think it might be possible to get a long drill bit and drill a hole in the curved pipe to the right of the letter "k". This could be done without taking the muffler off the car. It would just involve sticking the drill bit down the tail pipe and drilling away.
This would hopefully have the effect of making the stock muffler sound just like a new $1,500 exhaust - not too loud, not too soft and no drone. On the other hand, it might ruin the muffler entirely.
#52
My idea is to have a way to open it straight thru or close it back through the packed chamber. I am looking to have a way to run it open for track and close it back for street. I have seen the mods for installing e-cutouts right by the tranny - and I have a whole separate factory exhaust to cut up to do that - but this muffler butchering is worth exploring first.
#53
#54
You'll need one heckuva long drill bit - and unless its pretty big around, you may want to put a couple of holes in it.
#55
Good discussion....my thinking is that whatever we do, it will only be good for sound, I wouldn't expect any increase in power....but that's all I want is 10- 20% more sound...
I have a long drill bit and am going to see if it goes down the pipe....
#57
Put the barrel of a shot gun up the tail pipe and pull the trigger...problem solved!!!!
JUST A JOKE....Dont do that!
But if you do....we want to know all the results...with pics
#58
If one had the measurement of each dividing panel within the muffler maybe a hole could be drilled in the bottom and the fiberglas removed. The hole could then be plugged. If there was to much drone/noise ect. one could add the fiberglas back.
Can someone provide these measurements? Hell I'll try it.
