how do I set the clock?
Old 02-26-2008, 09:51 AM
bobk95945
bobk95945's Avatar
Default how do I set the clock?
I have the standard 1 CD radio and cant figure out how to set the clock to NOT show 24 hr time(Military) cant seem to find it in the manual
Old 02-26-2008, 10:00 AM
*FAÇADE*
PHOTOSHOP SPECIALIST
Support Corvetteforum!
*FAÇADE*'s Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
You're absolutely correct, the 2005 Owner's Manual does not address your issue.
This is taken from the 2006 Owner's Manual - hope it helps:
Old 02-26-2008, 10:02 AM
bobk95945
bobk95945's Avatar
Default thanks
thanks for the info ...am going to try that right now
Old 02-26-2008, 10:34 AM
Wayne O
CF Senior Member
Wayne O's Avatar
My 2005 owner's manual has information about setting the clock:
Setting the Time
Press the H or the M button to enter clock mode. Press
and hold H until the correct hour appears on the
display. Press and hold M until the correct minute
appears on the display.
Old 02-26-2008, 10:44 AM
bobk95945
bobk95945's Avatar
Default that worked
cant believe after messing with the clock for the last week thats all it took...thanks again
Old 02-26-2008, 11:01 AM
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Setting the Time
Yep, but nothing about switching between 12-hour time format and 24-hour time format.
Old 02-26-2008, 01:47 PM
300mph
300mph's Avatar
For once I can't use the RTFM comeback.
Old 02-26-2008, 03:42 PM
degaux
degaux's Avatar
... praise the Lord and pass the mustangs... I've been looking for this FOR MONTHS!!! .... thank you! thank you! thank you!!
Old 02-26-2008, 06:07 PM
jimmyb
jimmyb's Avatar
Received 4,248 Likes on 2,023 Posts
I know, I was going to jump also, then saw that it was a 2005 and remember going through the same thing (I kept hitting buttons and ***** till it changed to 12 hours, never knew how it got changed!!!)
Jimmy
Old 02-27-2008, 06:10 AM
foremaw
foremaw's Avatar
St. Jude Donor '08-'09-'10-'11-'12
Wow, those Owner's Manuals were a really good idea.
To how do I set the clock?
Quick Reply: how do I set the clock?
