Is it OK to swap out the stock radio for Aftermarket one
Brought my new 07 vette back to dealer because of bad battery, car wasn't starting after the radio & interior lights were left on in ACC mode for only 10 minutes after shutting off car. The car was in the dealer showroom for a year being show to customers & constantly draining the battery.
They just informed me that they are replacing the battery BUT the computer is constantly searching for moduals & not finding them. The stock radio was removed & replaced with:
http://www.oeradio.com/product_GM-5100.html#
The new radio does shut off automatically when the car shuts off.
but the vette amp is still being utilized. No speakers or amps were changed just the head.
The dealer wanted me to be aware that the computer may be draining the battery because it is always searching for the old radio/modual, EVEN WHEN THE CAR IS OFF!
Is this mumbo-jumbo? Should I be concerned with this? I see a lot of you guys changing out your radios, are there any computer related issues with doing so?
Steve
Steve
Is there something special about this particular kind of radio? The website calls them OEM-style radios - could there be something to this? The OEM radio in the Vette does communicate with the car - you can't swap radios, for example, without the codes that a GM tech enters (theft deterrence).
Steve
Steve
re: radio
I have seen lots of corvette batteries go bad for whatever reason cheap lead made by the lowest bidder. If the seven year battery last three years your pretty lucky. Also seen lots of problems with cheap ipod adapters staying on killing the batteries. The retained accessory power should shut everything off after 10 minutes unless someone wired the replacement radio to the wrong circuit and it is keeping a module from going to sleep. The dealer should be able to do a simple draw test to determine if something is staying on.
It could be the AMPs
For the standard audio and the Blose, the amp(s) (and the differential antenna) they are turned on and off by a signal from the radio call ANT Enable. If the radio is not controlling this signal correctly, the AMP(s), antenna, and XM receiver (if equipped) are staying on. The B+ for the AMP(s) come directly from the under-hood power distribution fuse block and are hot at all times. Without checking the AMP wiring there is no way to tell if they are on. The computer will not “be looking” for modules as long as the ign/*** is off and the fob is far enough away. I completely replaced my Blose system in my 2005 DSOM and the computer has no issues at all. In fact when I put the factory nav back in to figure out the antenna, it never complained just went right back to working.
