Remote visor garage door opener too complex.
my 08 only took a few seconds longer than my Infiniti, one more button to push
Checked with the HOA - no one knows anything about a Master.
Called the Electronic Gate people - they said only the HOA has it, but for $100 will come out and read off the dip switch settings to me.
Totally irritating - my original Homelink visor worked great. Got a new visor under warranty because the vanity cover broke.
I now have car2u and it sux....
Have 2 different garages doors that I've tried to program to work that both have fixed codes, not rolling, and have been unable to get them to work with '09 visor. Dealer says it will not work with a fixed code door. Has any one been sucessful programming a FIXED code garage door with the new visor? If so, I will keep trying, if not I will be grumpy. BTW, programmed doors on Honda in minutes.
that is what I had to do....get on a ladder, press the program button on the opener and then push the necessary buttons on the visor within 30 seconds. it worked the first time. my garage door opener is 10 years old and was not on the 'approved' list at the car2u site
#33
--- Other than having to climb up, open the side of the garage door opener and pressing a button to put THAT in program mode as well...it was a snap and worked the first time...........
#35
Lear Sucks
The new Lear unit sucks. Another instance of GM trying to save a couple of pennies. The original homelink units were much easier to program and worked with pretty much anything and you didn't need to worry about dip switches they just learned the codes. I wish GM would focus on the things that really mattered when looking at cost reductions or simplifications.
#38
#39
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
Programmed my '05 no problem.
Was only successful programming button #1 on my '08. Dealer replaced the visor, now I can't program any of them.
