Do you have your build sheet?
#161
I left a message for Betty at NCM. She called back promptly. I was told my 2009's build sheet is available. I ordered it and should have it by the end of the week. I'll frame it with my original window sticker. I think it will be nice to keep, and put on display with the car if / when I show it.
I too am framing with the window sticker. It will be a big frame. Should be complete this weekend.
#163
#164
I received my build sheet - the original - and have been looking it over. Is there a "map" for what each area means? I believe my engine (box noted as "ENG"), for example, is a ZAK. What does that mean? There are loads of other boxes too...
#165
Got my build sheet during my museum pickup, but why cant they just stick the original sheet in the car golve box etc when the car leaves the factory. What is the big deal about this? It should be part of every car that is sent out! I sure would like to have my original that was on the car as it headed down the line instead of a copy laminated at the museum!
#166
Ordering the build sheet from the NCM for a 2008 would state on there what color seats it came with from factory?
Buddy of mine got a new 2008 with gray seats, well anther buddy of ours said his car in the dealer originally came with black seats but before he ever saw this one, another customer of the dealer wanted black seats in his so the dealer swapped seats from two different cars. His window sticker does say ebony interior but nothing specifically related to the seat color.
#167
Cheap frames can destroy your Build Sheet, photos and other documents
I've noted here that several people are using an inexpensive plastic poster frame to display an original Build Sheet. This is fine for a casual display (i.e., at shows or in your garage), but if you're interested in keeping the Build Sheet "forever," it's a really bad idea. Even at medium humidity levels, moisture can get between the paper and the plastic surface of the frame; you usually can't see the moisture, but you'll know it's been there someday when you try to remove the Build Sheet from the frame and the paper (or the black print on it) sticks to the plastic. This sometimes also will happen because of a chemical reaction between the ink on the paper and the chemicals in the plastic.
A better idea would be to use an extra-deep (or even shadow-box style) metal frame with glass that doesn't touch the Build Sheet; instead, you hang the Build Sheet from the backing board in the frame with special paper "hinges" made especially for this purpose. Of course, if you want to be really **** about it, you can have the Build Sheet conservation framed, using UV glass and acid-free materials for matting and backing – but that's too much, even for me!
#169
There's always more than one
I just received a second "original" build sheet for my 2007 coupe from the museum.
The first one I've had for two-and-a-half years; it was taped to the front of the car as it went down the line – at least from the first time we saw it at the "marriage" of the body and the chassis during our Buyer's Tour. It was given to me by one of the workers just after I started the car at the end of the line.
The second one must have been the one that was taped to a few other other areas of the car, being moved as necessary so it would always be in plain sight as the car was being assembled. This one is much grubbier than the first one.
I wonder how many full build sheets are at some point attached or removed from a C6 as it goes down the line? I know there are several other, smaller pieces of paper that are attached and removed from various parts as the car is assembled, but I was told I couldn't have those. My Buyer's Tour was one of the early ones, and the rules were very strict at that time about what you could and couldn't do …
#171
ZAK is the LS3 engine. The best place I found to look up these codes is the Corvette Black Book, which is published every year. It gives all the specs on a year by year basis. NCM sells them.
