Convertible Top won't go back up
Old 09-01-2008, 09:29 AM
bill's red roadster
bill's red roadster's Avatar
St. Jude Donor '12
Default Convertible Top won't go back up
The convertible top on my 2007 C-6 went down by pushing the automatic button on the dash. I cleaned the interior with C-magic(it works great). However, the top will not go back up by pushing the button. Any suggestions?
Old 09-01-2008, 09:32 AM
Daytona Bob
Daytona Bob's Avatar
St. Jude Donor '09 & '12, '14
Assuming its in park / brake is up
I'd look at doing the manual procedure in the owners manual.
Old 09-01-2008, 09:45 AM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Are you hearing any sounds eg. relays clicking, etc.?
Old 09-01-2008, 09:47 AM
E Stumpff
E Stumpff's Avatar
Did you happen to lower the flap in the trunk that hides the top when it's down. There's a switch on the passenger's side that is close when you snap that flap back into place and thne the top will go up. I mention that because you said you were cleaning and you may have lowered the flap to clean behind it.
ED
Old 09-01-2008, 09:48 AM
Tom_Slick
Tom_Slick's Avatar
I always make sure the car is running before raising/ lowering the roof. Sometimes when I have the car in aux mode to listen to the stereo while cleaning/ detailing the car, the top acts weird if I try to raise/ lower the roof without starting the car/ bringing the battery charge back up.
Old 09-01-2008, 10:28 AM
bill's red roadster
St. Jude Donor '12
Default Top won't go back up
Thanks. I did fully charge the battery. I hear no clicking or whinning(just from me). I checked to mak sure the flap was in place. I started the car and pushed the button. I guess I'll just do the manual version and take it back to the dealer. Thanks for all your help.
I'm new to owning a Corvette and you people have been most helpful.
Just got back from Bowling Green and that is why I cleaned it. Never had a problem in Bowling Green. Thanks again.
Old 09-01-2008, 10:32 AM
*FAÇADE*
PHOTOSHOP SPECIALIST
Support Corvetteforum!
*FAÇADE*'s Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
The power top will not operate if the windows are not working properly.
If your battery was discharged, your windows may need to be re-indexed by doing the following:
Hope this helps!
Old 09-01-2008, 11:47 AM
bill's red roadster
St. Jude Donor '12
Default Top won't go up
Thanks. I did the indexing and the top worked again!! The battery showed 10.32 volts. That was yesterday. I put the battery tender on it and it now reads 13.23. That was all it took. Thanks again.
The following 2 users liked this post by bill's red roadster:
John 511 (01-14-2021), Ricktfd (12-12-2022)
Old 09-01-2008, 12:23 PM
cclive
cclive's Avatar
There's Facade getting that pesky owners manual in the way again!
Old 07-20-2018, 08:41 AM
Jwmanzetti
8th Gear
Jwmanzetti's Avatar
Default Convertible top on C6
resetting the windows worked! The top is functioning. Many thanks
Old 01-12-2021, 07:31 PM
Rick2008
7th Gear
Rick2008's Avatar
As I kept reading I found something about windows not being adjusted if the battery had run down. I ran the windows up then back down. Then the top came up as usual. Thank you very much!!!
Old 01-12-2021, 10:16 PM
owc6
owc6's Avatar
Received 4,186 Likes on 2,679 Posts
ED
This scenario also comes with a message on the DIC. ATATCH TRUNK PARTION.
Old 01-14-2021, 11:16 AM
John 511
John 511's Avatar
Good to know, good info.
Old 04-22-2021, 07:29 PM
jimcat1
jimcat1's Avatar
Had same problem, brought to dealer.....and after holding overnight, they said it just worked....Hmmm. I did have an window indexing issue, that I reset after it was brought home.....Will test, and won't be afraid to lower top on a nice NE spring day for fear it won't close....
Old 04-23-2021, 02:17 AM
Knob Jockey
Knob Jockey's Avatar
St. Jude Donor '11-'12-'13-'14-'15
Windows not being indexed is the one thing that will prevent the top from moving and not give you any kind of warning in the DIC.
You should learn how to put the power top up/down manually as well. It's easy but you do need an Allen Wrench.
Old 12-12-2022, 05:54 PM
Ricktfd
1st Gear
Ricktfd's Avatar
I was having the same problem and totally forgot about the window indexing. Thanks for the reminder. Now to put everything back together that I thought it was. Lol
To Convertible Top won't go back up
Quick Reply: Convertible Top won't go back up
