***New Product*** C6 Acrylic Driving Light Blackout Kit
#83
how do these hold up to automatic car washes? and what is the life expectancy of the tape? does it need to be replaced periodically? and is there any other adhesive ideas instead of tape?
#84
I do not run my car through auto car washes!! However, I believe I was the first to have these rear blackouts on my 08 black z06 and no issues what so ever. I have some extra tape in case I need them. They are awesome and so is RPI
#85
just placed an order... I was wondering if I could get some extra 3M VHB tape packaged with my order in efforts of being able apply tape the to taillight kit I already have that is missing the 3M VHB tape and a little extra for backup purposes.
#86
Got my side marker covers in today. They look good, stick out a bit more than I would like, but they look better than the window tint I originally put on...
Question though, the 2 fronts, you can see the yellow marker coming through on the top. Any recommendations on what to do?
#87
Platinum Supporting Vendor
Great, these wont come off without you tearing them off, which will require enough muscle you will snap them in half before the tape releases.
#89
PM sent
#90
We finally have the C6 Driving light blackout kit available. This two piece kit is made from pre-molded acrylic and attachs with provided 3M VHB clear tape.
These are designed to install in under 5 minutes and change the entire look of the C6!!
Price: $62.95 /set
In stock here: http://rpidesigns.com/shop/item.asp?itemid=1317
We've also got the rear blackout kits in stock:
And the side marker blackout kits in stock:
And the reverse light blackout kits in stock:
Price: $62.95 /set
#93
Just a little prop for RPI. Great products, great service and no run around. I have bought many items from RPI over the years for my cars and Corvettes that I work on for other people. I highly recommend them, you will not be disapointed.
#94
Price: $62.95 /set
V
Price: $62.95 /set
V
Do you have to remove them to put them on so that you can get all edges
#98
No need to remove the lights. Just carefully install them and they should be centered.
