iPOD PAL? Yet?
#41
I bought and installed a LockPick adapter a couple of weeks ago in my 2009 Coupe with Nav system. It works pretty good. Installation was fairly easy (no need to remove the dash). I can change between all of my playlists from the Nav screen. If your iPod is set to shuffle songs, it will continue to shuffle songs. It appears to the radio as an XM station. It shows the artist and song name at the start of each song. It sounds good and beats waiting for GM's version. Only issues I have seen with it are that I don't think I can get to my podcasts and I need to reselect it each time I turn the car on again. I'm 95% satisfied with it and it sure beats any FM tuner solution. If the GM PAL ever comes out, I may switch it out if the PAL is better. Until then, I'm enjoying my tunes!
- Mark
- Mark
#42
Corvette PAL
The Corvette PAL Development is complete. It currently is designed for NavRadio only. The Non-Nav should be a month or so after the NavRadio. Unlike big foot ...it is real. It is currently in the release process.
#44
St. Jude Donor '06-'07-'08-'09-'10,'14
Sorry, but I'm not biting. When I have it installed in my car and can control the Ipod from the touchscreen then I'll believe. Till then, cds are cheap and the touchscreen works - unlike the other cheezy gizmos - lockpick included.
#45
I'm going with this from Coastaletech. I have the lockpicks and iPod adapters in my other cars and they work great.
http://www.coastaletech.com/CORVETTEIPOD.htm
#46
Music Device Capability is a factory-installed option exclusive to Cadillac CTS that is designed specifically for the iPod. Play lists appear directly on the car's radio display through conveniently located USB and auxiliary audio jacks.
