Any way to reduce drone?
Old 01-06-2017, 02:31 PM
  #41
Dutch08
CF Senior Member
Originally Posted by SUB VETTE View Post
Buy a set of Corsa Sports.
It took me a long time to decide, I finally went with Corsa Sports, and Corsa X pipe. In my opinion, after owning them about 2 months now...
The Good:
* Strangely quiet in cruise between 1600-2000 rpm (No drone, nothing)
* Awesome snap, crackle, pop on decel
* Awesome start up sound
* Awesome sound on accel
* Good, nice sound while running the gears
The Bad:
* Fit - did the install myself, nearly impossible to get the mufflers to line up (I'm a bit retentive about that stuff.)
* Overall a bit high pitched more of a European sound than muscle car
* Small RPM range has a sort of a motor boat 4 cyl sound -sometimes ????
* Sound level is probably perfect, but I'd like a bit more sound on hard accel, and bit lower rumble. (Maybe should have bought the Extremes.)
Again just my personal review, just trying to help.
Dutch08 is offline
Old 01-06-2017, 05:04 PM
  #42
Redhook98
CF Senior Member
Redhook98's Avatar
The Good:
The Bad:
Just did similar. I had Kooks headers and x-pipe with BB Bullets. Had to quiet that down so my teeth would not rattle inside the car. Put a pair of Corsa Sports on and observed the exact same points you made. I like em a lot, but do wish they were deeper. The Bullets made it sound totally bad *** with the cam. The Sports mellowed that. :-(
But most important, NO DRONE at all!
Redhook98 is offline
Old 01-06-2017, 05:11 PM
  #43
cmonkey713
CF Senior Member
cmonkey713's Avatar
Corsa Sports seem to be the fix for the dreaded drone.
cmonkey713 is offline
Old 01-07-2017, 01:17 AM
  #44
Bigwebb
CF Senior Member
Originally Posted by Reggied View Post
Added high-end padding in the floor, doors, and rear compartment. Heat from muffler and transmission reduced a lot. Drone is slightly reduced but your ears will re-adjust to the new level of drone which makes it become a problem again. The trick is always drive in 5th gear. It puts you in a range that drone is not the main noise.
The padding did help a lot with road noise.
Also running regular tires and not run-flats reduce the road noise a lot too.
I love the sound...I think I have MidAmericas the set that's in the middle between mild and crazy loud.
I have a 6-speed manual 2005
The noise is coming from the entire car resonating at a low frequency being amplified by the shape of the rear compartment glass. Like standing in front of a megaphone.
and THAT is why I bumped an old thread. Thank you sir. That post made my decision for me. Not going down the rabbit hole. If I get tired of it, ok switch to NPP or corsa. Thanks again.
Bigwebb is offline
Old 01-07-2017, 11:15 AM
  #45
Redhook98
CF Senior Member
Redhook98's Avatar
Mine came with all the fancy padding in the hatchback area and behind the seats. Made zero difference in drone. Only affects road and tire noise. As some stated above, the drone is caused by resonance in the hatchback and underside cavities. No padding will fix that.
Old 01-08-2017, 03:59 AM
  #46
drive2fast
Junior Member
My aps twin turbo mufflers droned at certain speeds , I wrapped the mufflers themselves with dynomat and then wrapped very very tightly over the dynomat with header tape and it really stopped most of the drone.
drive2fast is offline
Old 01-08-2017, 03:14 PM
  #47
64Ragtop
CF Senior Member
64Ragtop's Avatar
Corsa Sports work for me!
64Ragtop is offline
Old 01-08-2017, 10:51 PM
  #48
TWOBUELLS
CF Senior Member
TWOBUELLS's Avatar
Default Corsa Mid -Pipe
I have a Corsa mid-pipe that is meant to cut down on drone and excessive noise. $200.00
TWOBUELLS is offline
Old 01-08-2017, 10:58 PM
  #49
vazz98
Junior Member
Borla Atak with the Borla H pipe. No drone at all. Not that loud either. 2007 A6.
vazz98 is offline
Old 01-09-2017, 01:09 AM
  #50
ProfessorDeath
CF Senior Member
ProfessorDeath's Avatar
St. Jude Donor '13-'14
A cargo partition works surprisingly well. Your stereo will sound better as well.
ProfessorDeath is offline
Quick Reply: Any way to reduce drone?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
