Where does Z06 come from
It was an RPO (regular production option) number in the early 60's. All GM options are usually 3 digit codes and "Z" and "F" codes are usually suspension options.
Moderator
Received 3,570 Likes
Location: ,fl.Never, under any circumstances, take a sleeping pill and a laxative on the same night.
Z06 High performance option for 1963 model,also high performance
(hardtop)C5 model introduced in 2001,and high performance C6 coupe based model introduced in 2006
From this page:
The RPO Z06 package first offered on ’63 models included a 20 percent larger diameter front antiroll bar, a vacuum brake booster, a dual master cylinder, sintered-metallic brake linings within power-assisted Al-Fin drums cooled by front air scoops and vented backing plates, larger diameter shocks and springs nearly twice as stiff as standard.
These Corvettes came to be known as known as the “Big Tanks” because the package initially had a 36.5-gallon gas tank versus the standard 20-gallon for races such as Sebring and Daytona. At first, the package was only available on coupes because the oversized tank would not fit in the convertible.
Had nothing to do with Zora. Originally RPO codes were grouped as to function, but as time went by, there was a lot of cross talk between function and RPO code. For example, by 1978, Z01=Monza Spyder, Z02= Monza Spyder Appearance package, Z03= Landau Equipment, Z06=Luxuy Equipment, Z14= engine Processuing-Non Integral Head, Z15=Spec. Sport Equip. SS-454, Z52=Seat-Full Foam, etc.
http://www.crankshaftcoalition.com/w...rs_build_codes
From this page:
