Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Reload this Page >
Take Care of Your Clutch--Preventing or Curing Pedal Issues
Old 04-01-2009, 11:41 AM
  #81
jeffjob
POSSE Senior Hombre
Support Corvetteforum!
jeffjob's Avatar
Recieved 58 Likes on 43 Posts
St. Jude Donor '13, '17-'18
Originally Posted by pTr73 View Post
I picked up a 60cc irrigation syringe at a medical supply place. Cost was about $1.50
Walmart has them...
jeffjob is offline
Old 04-01-2009, 12:08 PM
  #82
flatlander1295
CF Member
flatlander1295's Avatar
Recieved 0 Likes on 0 Posts
Great post very imformative and descriptive.
flatlander1295 is offline
Old 04-01-2009, 12:29 PM
  #83
pTr73
CF Senior Member
pTr73's Avatar
Ok, first off this thread offers the most informative literature I have ever read! Thanks Ranger!
I just performed my fluid swap... The initial fluid in the resevoir was murky and appeared very dark. I sucked it out with the syringe and cleaned the resevoir out. Poured new fluid and pumped the clutch pedal 30 times. Came back out and only seen a few dark swirls of clutch dust. Maybe it wasnt that bad, but I will keep my eye on it the next time I take the car out.
pTr73 is offline
Old 04-01-2009, 02:47 PM
  #84
sngyu
CF Member
can i use a dot3 brake fluid.
sngyu is offline
Old 04-01-2009, 05:21 PM
  #85
FastEddie09C6
CF Senior Member
FastEddie09C6's Avatar
Recieved 14 Likes on 5 Posts
did my fluid swap today came back murky twice so i did it about 4 times and now it looks great.....this is def the most informative bunch of people i have even come across thanks guys and it makes owning a corvette just that much more fun knowing that you have this wealth of information from so many people available
FastEddie09C6 is offline
Old 04-01-2009, 07:46 PM
  #86
pTr73
CF Senior Member
pTr73's Avatar
The owners manual says to use Super DOT-4 brake fluid why ask for trouble?
pTr73 is offline
Old 04-01-2009, 07:48 PM
  #87
pTr73
CF Senior Member
pTr73's Avatar
I did mine today also, yesterday i had the car out and the pedal got stuck to the floor. I cleaned mine took it for a short ride and it got darker again. I hope I didnt blow a seal that its getting dark fast like that.
I am from SI too! We probably passed each other on hylan!
Welcome to the forum and congrats on your new vette! You picked the right color too!
First mod should be to take the stock mufflers off and replace them with some stingers...
B & B and Corsa are fine also but the stingers give it a subtle growl.
pTr73 is offline
Old 04-02-2009, 12:07 AM
  #88
LT1 Z51
Corvette Enthusiast
LT1 Z51's Avatar
Recieved 621 Likes on 452 Posts
I think the first time you do it that it will take 5-6 times to get it clean. I changed it out 3 times, drove it a few days and it is black again. I am going to change it out 6 times this weekend.
LT1 Z51 is offline
Old 04-02-2009, 07:01 AM
  #89
pTr73
CF Senior Member
pTr73's Avatar
That is comforting to know, I better buy another can of DOT 4.
Pumping my clutch pedal (car parked) isnt cycling it well. I just figured driving the car (creating dust) and a blown hydraulic seal that was the reason it got dirty really fast.
pTr73 is offline
Old 04-02-2009, 04:49 PM
  #90
Ranger
CF Senior Member
Ranger's Avatar
Recieved 7 Likes on 5 Posts
When doing the pedal pumps after swapping the fluid, be sure to allow the pedal to cycle into the full-up position on every stroke. If you miss the top by even a scant 1/8 inch, the valve to the actuator (slave) remains closed, preventing the mixing of new and old fluid. Full top-to-bottom-to-top cycles of the clutch pedal is what you want.
That said, driving the car works too; just add to the protocol duration.
Ranger
Ranger is offline
Old 04-02-2009, 05:20 PM
  #91
George Ware
CF Senior Member
George Ware's Avatar
Thanks for the info
George Ware
George Ware is offline
Old 04-02-2009, 05:40 PM
  #92
FastEddie09C6
CF Senior Member
well its good to know another staten islander is on here....btw i was driving today and i checked the fluid afterwards and it still looks good no black grime so i think so far so good.....
Old 04-02-2009, 06:32 PM
  #93
pTr73
CF Senior Member
pTr73's Avatar
Ranger
I think this is what I was doing wrong... I sort of kept my foot on the clutch (and it probably did miss by an 1/8"
I will do this again tomorrow bright and early, thanks for the heads up!
pTr73 is offline
Old 04-02-2009, 06:35 PM
  #94
pTr73
CF Senior Member
pTr73's Avatar
Good news, mine has black in it still. I may have to repeat this about 5 - 6 more times.
Ranger 1 quick question?
Is there a way to determine if I blew a hydraulic seal???
I keep thinking I did just that when my pedal stuck in the down position the other day during a hard launch.
pTr73 is offline
Old 04-02-2009, 07:16 PM
  #95
Ranger
CF Senior Member
Ranger's Avatar
It's not unusual for the clean-up process to take 20 swaps or so.
Regarding the hydraulic seals, once the fluid is clean and remains so, then you'll know whether or not a seal is compromised if pedal issue become chronic.
But pedal hangs on a hard launch can also reflect too slow a release of the clutch pedal. High-rpm pedal hangs with real clean fluid indicate a hardware issue.
Ranger
Ranger is offline
Old 04-02-2009, 07:49 PM
  #96
PeterM
CF Senior Member
PeterM's Avatar
Thank you for sharing all this great information.
PeterM is offline
Old 04-02-2009, 09:45 PM
  #97
need-for-speed
CF Senior Member
need-for-speed's Avatar
Recieved 36 Likes on 27 Posts
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03-'05-'07-'09-'10,17
Prestone DOT 4 is $3 at WalMart.
need-for-speed is offline
Old 04-03-2009, 08:20 AM
  #98
pTr73
CF Senior Member
pTr73's Avatar
Ranger
I did have the RPM's up to abour 3500 or so, then pulled the pedal to the half way mark (as the clutch bites). This time it only came up about 2 inches and hung there while I had my foot on the gas. The engine was revving higher as I pushed on the gas but the car wasnt moving. It was then I looked down and seen the pedal still down near the floor. I tried stepping on it and it wouldnt move until I took my foot off the gas. Then I noticed this strong smell of something burning... (smelled like brakes do when they get overheated). I suspect it was the clutch that took the brunt of this ordeal. It smelled like that for a while and then went away. I pulled over and popped the hood, I knew it had something to do with the hydraulic fluid. It was black and directly on the MIN line. At that time I drove the car easily back home, I kept thinking the clutch wasnt grabbing like it used to (probably in my head). But if I heated the clutch up that badly I assume it wont work as efficiently as it should. (when brakes get too hot they lose efficiency also).
pTr73 is offline
Old 04-03-2009, 08:37 AM
  #99
pTr73
CF Senior Member
pTr73's Avatar
I was just thinking... Do you think GM should fabricate and/or retrofit some type of filter for that resevoir to prevent the fluid from getting contaminated too quickly?
A filter would capture the dust and not bleed it back into the line. And it would be alot easier to swap the filters out when needed.
pTr73 is offline
Old 04-03-2009, 08:41 AM
  #100
Ranger
CF Senior Member
Ranger's Avatar
You glazed the clutch by allowing significant slip on the launch. The C6 clutch does not tolerate that well. That said, once the clutch cools down again, it's fine. Clean up the clutch fluid and all is back to normal operation.
Ranger
Ranger is offline
Quick Reply: Take Care of Your Clutch--Preventing or Curing Pedal Issues
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
