GCA (Genuine Corvette Accessory) Splash Guard installation w/ pics
#82
Premium Supporting Vendor
We will be happy to meet or beat any other competitor pricing.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
#83
Former Vendor
#86
Received 3,066 Likes
2021 C6 of the Year Finalist - Modified
I see they usually sell these splash guards as a set of 4.
How about people that own a ZO6 or a Grand Sport ... These cars already have rear splash guards from the factory, but need something on the front.
Do they sell a nice front only splash guard that matches the rear OEM splash guards that's already on the car?
#89
Not sure I understand the "overhang", but there is a small "hook-like" feature at the top of the rear splash guard that fits over the fender lip. If this did not get hooked, that could account for the overhang. Just installed mine 2 days ago and almost missed this step.
#90
3rd Gear
order this Splash Guards
Hello
I would love to order this Splash Guards, think this is not. Can you give me a link or an address?
Many greetings from Switzerland
Markus
Markus
The install is pretty simple over all. You do have to remove the rear tires but there's nothing difficult about that. Once installed they look like they came on the car. The fit is perfect and you can hardly tell they're there. Now I know some people say "mud flaps" don't belong on Vettes but these are far from "mud flaps" and don't forget they come stock on a Z06. OK now on to the install.
Here is everything ready to go.
You need these two tools to complete the install however you can just use a small screwdriver instead of the pry tool.
The drill bit is kind of an odd size and I didn't have one in my set but I picked one up at Lowes.
For the fronts you need to remove the push pins inside the wheel well.
Just pry the head up and pop them out.
This is what the push pins look like once removed.
The new push pins (on the left) are obviously larger than the stock ones but they fit with no problem.
This is what the back of the splash guard looks like. The red line is backing for the tape seal that helps secure it to the car.
Clean the edge with the alcohol pad provided.
Put the push pins in but not all the way.
You want to leave them like this until you pull the backing from the tape and stick them on.
Pull the backing off. Make sure you place it where you want it the first time because the tape sticks really well.
The directions say to push with 20-30 pounds of pressure and "iron" it on from the bottom. I have no idea how much 20-30 pounds feels like so I just pushed them on with a lot of force.
Once they are secured with the tape you can push the pins in all the way. This does take some force so push hard.
And here you go. Now just repeat on the other side. Then on to the rears.
#91
Someone asked why GM didn't include these on every car rather than making them an accessory. The answer is aerodynamics = gas mileage. Every little bit counts in meeting the CAFE requirements.
#92
Received 2,045 Likes
St. Jude Donor '13
Do you have any data or outside commentary to support the theory?
