Disable passenger airbag
Cruise-In VIII Veteran
You have a weight sensor built into the passenger seat that automatically determines the need for the passenger air bag. There shoud be a display in the lower portion of the rear view mirror that tells you if the switch has the passenger air bag turned on or off.
The manual airbag switch used in earlier models is no longer used since it's now an automatic function.
In 2006 and newer, the switch for the passenger side airbag is build in to the seat. It uses a weight sensor and automatically detects if a child or carseat is present and automatically turns off the airbag. There is no longer a manual switch for the passenger airbag present.
Heidisman1969 (04-28-2023)
