Memory seat button sticks. Can I use a spray cleaner on it or will that cause more problems. Tried cleaning around it with a Q-tip but didn't help. Any ideals?
I would try contact cleaner from any electronics store. It is inert, won't affect any surrounding material, and it definitely won't hurt the switch electrical contacts (that's what it's for). Of course, I would also spray a little on a bit of trim that doesn't show just to be sure.
I had a similar problem and contact cleaner worked fine and did not leave a residue on the door panel.
Try blowing out around it with some air first. If you don't have access to a compressor you can get one of those little cans they use to clean keyboards with.
