Brake bleeding troubles
even using my mty-vac, I still hardly get fluid out of the rears. Not sure why you are having these issues... I doubt you need to bench bleed the master. You don't need the scan tool for the ABS to bleed the system.
It sounds like you still have some air trapped. I use a pressure bleeder with good results. Did you follow the recommended pattern? I think it starts pass rear, drivers front, etc... not exactly sure..
Try the procedure again with the proper sequence... sometimes the air gets trapped in the brake line distribution block which is why they have a rotation sequence.. good luck
Usually you have a very hard time bleeding and getting a firm pedal when they are upside down like that.
Bob
The Service Manual says that after after raising the car and removing the wheels, you should pump the brake pedal 3 to 5 times (or until there is an increase in pressure) to allow the brake booster pressure in the system to be relieved.
The master cylinder has a baffle in the middle to divide it into a front and rear reservoir - you add fluid to the rear and when it gets to a high enough level it flows over the baffle into the front reservoir.
For safety, the brake system is divided into 2 circuits - the RR/LF, and the LR/RF. In the event of a leak or damage to one of the circuits, the other one should be able to stop the car.
I think the front reservoir in the master cylinder supplies fluid to the RR/LF wheels, and the rear reservoir is for the LR/RF.
The Service Manual says when bleeding to bleed in the order RR, LF, LR, RF.
So....all that still doesn't give any good insight into the OP's issue of not being able to get a good fluid flow from the rears when bleeding.
The only thing I can think of is that perhaps there is something restricting fluid flow through the rear calipers. I have a Motive Power Bleeder, and I only need 10 to 12 psi to get a good fluid flow when I open the bleed valves. You may have to remove the rear calipers and make sure the fluid path isn't clogged by debris.
Good luck!
Bob
What I saw a Harley mech do once, was to put a vacuum hose connection into an extra MC cover and use the mite-vac to bleed from the pads to the MC. Worked great. On mc's I get a large syringe and pump the fluid from the caliper to the mc. Works great.... for those that have Harley's and do their own maintence. Not sure this would work on an ABS sytem, let alone a brake system as large as a car. You'd need a very large source to pump the fluid thru that much hosing.
John
Keep your foot off the brake and continuously hold the button for 5 secs or more and you will get "ignition on."
Edit: I should have been more clear in saying to push on the bottom of the button. But still keep your foot off the brake just in case you push more on the top of the button to keep from starting the car.
Push on the pedal just like you were bleeding the calipers, crack the brake line fitting at the master cylinder and make sure no air bubbles are coming out. If you did let one side of the master cylinder go dry, and you do not get it bled, you will never get all the air out of the system.
I agree that the ABS valves should be normally closed so you should be able to manually bleed the system without actuating the ABS system.
When bleeding the ABS with a Tech 2, the Service Manual tells you to turn the ignition ON with the engine OFF.
However, if you are servicing the EBCM (Electronic Brake Control Module) or the BPMV (Brake Pressure Modulator Valve), the Service Manual says:
IMPORTANT:
- The ignition switch must be placed on OFF mode ONLY, before disconnecting the EBCM. If the ignition is accidently placed into ignition ON engine OFF mode, the control modules will be activted and dixonnecting the modjule or negative battery cable will cause various DTCs to be set.
- After the ignition switch is placed into OFF mode, a waiting period of 2 minutes must be observed to allow the high-speed LAN control modules to deactivate before disconnecting or connecting the module or negative battery cable. If the waiting period is not observed, one or more of the control modules may still be active; tihis will cause various DTCs to be set.
As I said above, the manual doesn't make any mention of ignition ON or OFF or any waiting time before doing a normal bleed, but the above does indicate that for a period of time after shutdown some of the valving in the EBCM/BPMV may still be cycling. That could cause a problem when trying to bleed the system. By the time I'm ready to bleed, the car has been shutdown for several minutes and all the valves should have been where they need to go after ignition shutdown.
Bob
Although there is no proportioning valve, there is DRP (Dynamic Rear Proportioning), which is a function of the ABS modulator. The Service Manual says:
Good luck!
Bob
