Finnaly lowered my C6...found easier way.
Location: Some where in Amerika, sadly watching how is turned into a Socialist Republic.
I finally found a little time to work on my car and the next on the list was lowering, I seen many post on the matter and I wanted to do it with minimum disassembly, or non at all.
I wanted to lower it just enough to eliminate the unsightly gap between the tire and fender, nothing radical.
I got a set of rubber pads from Ecklers, they cost less than the bolts, with the same results, and I also had no intention on removing the bolts from the springs, that required removing the shock and sway bars, I instead did it this way.
After lifting car and placing a stand on the spring to relieve the tension I used a sharpened gasket scraper to slice the original factory rubber pads, and any excess glue that remained, I then slipped the new pads and I was done. I spent more time lifting the car than doing the actual work.
After driving the car to settle the suspension a quick check on the alignment showed no changes from factory settings. The difference in handling is very noticeable.
Next on the list, finding a nice set of wheels, with the same offset as the factory ones, the K&N induction should arrive monday, and thats a 30 minute job.
Cool. I did not know that this alternate method was available. So no turning of the bolts? How do the new pads stay in? You say you just slipped in the new ones. Also, can you post the part number or other identifier to finds them by? Finally about how much owuld you say it cam down? Mine is already a little lower due to the Koni FSD's. I would like to estimate how much lower I would be via this method.
thanks
thanks
thanks
thanks
Ecklers part #48719, The pad just snaps in place it has a lip, I lowered mine 1 3/4 inches. I can still come down some more in the front but I wanted the same gap fron and rear. I did turned the bolt up into the spring, but thats very easy once is unloaded.
thinner pad
saved yourself some labor & $$...congrats!...thought about just the thinner pad vs replace the complete bolt..wanted to keep the stock bolts unmodified to replace in case of future sale.
One last question. It seems from the pic that the new pad is about half as thick as the OEM. Would it stand to reason that just that difference would lower the car some without turning the bolts at all? If so that is what would work for me. Looks like 1/2" less on the pad and the 1/2" to 3/4" that my FSD's lowered my car would provide just what I want.
GaVette61 (04-09-2021)
Yes they can, but changing out or eliminating the bushings allows for more of a drop. In some cases the bolts have very little play left and the bushing have to come out to achieve any kind of drop.
I used the same thing, and both of my rears came off during normal driving. Everything was fine for about a month, roughly a 1000 miles, then I noticed a squeak in the rear. Come to find out the slip on pads came off and it was metal to metal. Just be careful and watch out. I ordered new bolt with the polyurethane bushing molded around the bolt. Good Luck
