Another paddle shift question/comment....
Old May 14, 2009 | 05:17 PM
RussellZ's Avatar
RussellZ
Default Another paddle shift question/comment....
I've read several posts where people comment that the delay in the paddle shift is excessive. It seems to me that there is also a delay on a manual transmission. Let me explain. When you push in on the clutch and move the shift lever, you are actually putting the car into a neutral position for a fraction of a second. Although you may not perceive the pause, it is still there. Does this make sense? Maybe I'm explaining it wrong. Will someone please educate me. I'm just curious.
Old May 14, 2009 | 05:23 PM
06 C6 vert's Avatar
06 C6 vert
A little off topic , but the "delay" with the A6 is what is called " flare ".
This is built into this type of trans for longevity reasons. With this much power with this type of trans shift shock can be an issue, so the built in protection. The Vette trans is fairly low tech.
Old May 14, 2009 | 05:29 PM
mcwire's Avatar
mcwire
Originally Posted by RussellZ
........................... It seems to me that there is also a delay on a manual transmission. Let me explain. When you push in on the clutch and move the shift lever, you are actually putting the car into a neutral position for a fraction of a second. ...............
I suppose that this is technically true. The speed at which you complete the process, determines the time of the "pause". -- --
Old May 14, 2009 | 05:42 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
True, Russell. But we've "evolved" to where some see the "clutchless-automatics", "manumatics", "auto-manual" transmission, etc. of the Formula One Ferraris, and street Porsche, BMW, etc. And some think that Corvette automatics should have delay-less shifts that just bang from one gear to the next, up or down. To do that would require a very different trans, at a different price, and with a more stringent maintenance schedule I would suspect, not to mention a R&R process, too.
The fact is most who do modify the shift pattern of their cars won't own it long enough to have anything bad come of it.
Old May 14, 2009 | 05:43 PM
Gordon Shumway's Avatar
Gordon Shumway
Your premise is correct. There is, of course, a delay. However, it is no worse than the time it takes to do a manual shift. It is just more noticeable because you are not doing anything else, like actually shifting. The mind will play tricks that will drive you crazy if you let it.
Old May 14, 2009 | 06:52 PM
cmonkey713's Avatar
cmonkey713
Any good tuner can adjust to shift firmness and speed of the gear change. This will vastly improve the reflex of the paddle shift. I had mine done and the difference is amazing especially at WOT.
Old May 14, 2009 | 07:16 PM
Marc V.'s Avatar
Marc V.
This is not entirely true.I've been an auto tech for 20 years and can probably overhaul a trans blindfolded.
An auto trans will "flare" if it is indeed slipping a particular gear as it shifts. The RPMS will "FLARE" between shifts. If an auto trans is flaring, then there is a problem.
What the OP is describing is the delay from the time you push the paddle shifter until the time the trans actually responds and shifts. It is all in the software, and any good tuner can improved the shift response.
As far as a manual trans, the OP is correct. That's why a skilled driver will always be faster at the track. He can shift faster and more precise ( not missing any shifts) then a less experienced driver.
Old May 14, 2009 | 11:02 PM
hey32g's Avatar
hey32g
What are your feelings on the reliability of the auto if the shift speed has been significantly improved? If I did this would I be driving a ticking time bomb?
Old May 14, 2009 | 11:14 PM
Marc V.'s Avatar
Marc V.
Most trans tuners will boost the trans line pressure and will give the trans a firmer shift. It's just like a shift kit in an older auto trans. A sloppy shift is what can be detrimental to a trans, since it allows the clutch packs to slip more. If the clutches apply more quickly, there is less wear and less heat.
Remember that the Vette was produced to appeal to a wide range of customers, hence a smooth trans and a quiet exhaust, etc. You don't think the middle aged woman who buys a Vettes wants a trans that shifts harsh or has a loud exhaust?
Old May 15, 2009 | 12:31 AM
danl72's Avatar
danl72
Old May 15, 2009 | 12:33 AM
Dif's Avatar
Dif
I notice my A6 will shift a lot faster when accelerating hard and letting it shift on it's own in Sport Mode.
It shifts Slightly slower if I use the Paddles
Personally I "don't" want it to "Bang" into each gear.
Old May 15, 2009 | 09:54 AM
redzone's Avatar
redzone
Well said Bill.....paddles on the steering wheel do not make a true sequential transmission. I do hope they eventually offer an honest to goodness F1 style tranny,but it won't be cheap.
I have to disagree here.....a manual shifted properly can be measured in milliseconds whereas the auto sometimes takes as much as two seconds to shift.
Old May 15, 2009 | 10:26 AM
FloydSummerOf68's Avatar
FloydSummerOf68
The speed of the shift and line pressure does not effect the delay. It will make the actual shift faster, but the delay between hitting the paddle and the shift starting is still there.
I'd also like to comment about people talking abuot manual shifting. If you can't outshift the paddles then you dont know how to drive a manual.
Old May 15, 2009 | 11:54 AM
j_digi454's Avatar
j_digi454
Old May 15, 2009 | 12:58 PM
GaryW's Avatar
GaryW
You're absolutely right, a manual shifted properly can be measured in milliseconds; of course, so can the age of the Universe
Seriously, the consensus is that for a manual road-car transmission you're looking at 0.5-1.0 seconds to shift (i.e. from power-on in the old gear to power-on in the new gear). Or should I say 500-1000ms? Let's say 500ms if you know what you're doing.
Old May 15, 2009 | 02:33 PM
Hardluck's Avatar
Hardluck
I've got an 08 auto w/paddles I bought used. The shift response with the paddles seems to me to be almost immediate(maybe a half second). Does this mean the previous owner(don't know who this is) probably had it tuned? If so, is there and way to know if it has been previously tuned?
Old May 15, 2009 | 03:44 PM
redzone's Avatar
redzone
I never understood the point of dialing it down to milliseconds either,I was just repeating it the way it was written....why not just say 5 tenths?
I guess 500ms sounds faster than 5 tenths
To Another paddle shift question/comment....
Old May 15, 2009 | 04:05 PM
Gordon Shumway
I disagree right back at you.. There is no way on God's green earth that the paddles have as much as a 2 second delay (at least on an '08). I don't use them a lot, but I can assure you a shift is completed in less than a second (like between 500 & 1000 ms). Two seconds is an eternity relating to a shift. If it were taking two seconds, the villagers would be at the gates of the castle in Detroit with pitchforks and torches.
BSE1956's Avatar
BSE1956
But mine also seems somewhat variable when using the paddles depending on throttle input, RPM etc. Try it out.
Old May 15, 2009 | 04:23 PM
06 C6 vert's Avatar
06 C6 vert
With the factory tune using the paddles you will get good shift times if you build enough pressure up with similar revs as you would with a M trans. I cant see lugging the vette around in Drive or Sport mode. I am 100% paddles. Granted the factory tune wants to short shift to get better miliage numbers.
With a trans tune you will have more wear not less. More stress on the whole drive train. Plus it jacks up your warranty
