Strange NPP muffler valve rattle (with video)
Coming home from work today, I back the vette into the garage as usual ( 2008 3LT Z51 with NPP) and all the sudden i notice a metallic rattling noise coming from the back of the car, WTH so i leave the engine running, step out and head towards the back.
NPP valves in normal "closed" position.
VIDEO:
http://img190.imageshack.us/i/npprattle.mp4/
Im pretty sure the noise is coming from the valves in the NPP mufflers. I got back in the car and manually opened and closed the valves using my NPP manswitch and the noise went away completly. However, this has happened before and im sure it will happen again.
Has anybody else experienced this issue ? What was the solution ? Did you need to have the mufflers serviced or replaced under warranty?
- Mark
VIDEO:
- Mark
I have heard this a few times a never thought much about it.
The NPP valves use a mechanical linkage from the actuator to the valves. The pivot points of this linkage are loose (or a sloppy fit) to take into account road dirt, salt and other items that may buildup on the linkage over time. The sloppy fit allows the linkage to always function under most all conditions.
I believe what happens is that from time to time the valves open or close in just the right position that this "slop" (or tolerance in engineering terms) is at its' maximum and thus the linkage/valves rattle. Not a thing to be concerned with in my opinion.
Former Vendor
St. Jude Donor '09
if you have a vacuum leak this could happen, they need 14"HG to stay shut and thight, a little leak in the actuator or line could cause this. Other cause is a loose rod/nut on the actuator arm. You need to touch spots and see what stops the noise.
I put NPP on my '07 and they rattle for a second or two when I close them. I always wondered if that was normal. Sounds like your video only it lasts for only a second or two.
VIDEO:
- Mark
VIDEO:
- Mark
With the NPP exhaust,... that rattle can come from one of the Butterfly flaps.
If you grab the top of the linkage, where the rod goes down into the Butterfly valve, you'll find there is slight "Up and Down" play.
That's all it is.
Sometimes it might rattle .. sometimes not.
It'a muffler pipe and not a precision fit type thing.
And as you noticed, just open and close it .. and it goes away until maybe the next time it rattles a bit.
I noticed it once when I was standing in back of the car and just touched the top of it and it stopped it.
Just the nature of the beast
That's all it is.
