Can you add NPP exhaust system to an '08 ?
Received 2,060 Likes
Your problem is very simple. The mufflers are identical from '08 thru '13, but the difference is the angle of the pipes going over the axle.
Simple solution is to cut the pipe off of both the '08 and '09+ mufflers and weld your '08 pipe to the '12 muffler. Done deal. Just remember to put an alignment mark before cutting, so you know where to align the pipe before welding.
If only the Sunset Orange Creations controllers were still available for NPP. I was fortunate enough to get one that had been lying around Chuck Mosello's Corvettes of Westchester shop a couple of years ago when he installed an NPP set in Red. It's absolutely the perfect companion for the NPP exhaust system.
Others here can give you the details.
