Any tips on removing tar from body?
8th Gear
Hey, I have some tar just behind my two front wheels. I bought the vette used and thought it was just road marks from debris thrown up from wheels but upon closer inspection it appears to be tar. Tried bug and tar remover but that isn't working too well. I could not find anything on the search. Thanks in advance.
WD-40 works perfect and will not hurt paint.
I use a small dab of Gojo Hand Cleaner to get those bits of road tar. Put it on and let it sit a minute or two to soften and loosen the tar. Wipe off with a soft towel. If the glob of tar is large it may take a couple of applications. Finish by wiping it clean with a wet rag.
Even gasoline will work. Just be careful as you are removing it that you don't rub it very hard. That tar probably contains sand and you don't want to be sanding the paint.
Once you get it clean a coat of Rejex will make sure you never have this problem again. With Rejex tar just comes off during regular washing.
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
big red label with white cap spray can of 3M General Purpose Adhesive Remover, as recommended by detailer and clear bra installer. spray on very small patch of a rag about a quarter's size, then wipe off tar. can will last forever; mine's going on 4 years old.
A lot of chemicals go bad with time.
St. Jude Donor '15
"In honor of jpee"
"Isn't GOJO gritty and abrasive?? "
Nope, I use Gojo with lanolin. It is creamy soft. But it is wise to check any hand cleaner before putting it on a surface that could be scratched.
