If key less battery goes dead??????????
Old 11-04-2009, 11:06 PM
1955 copper
1955 copper's Avatar
2015 C1 of Year
Default If key less battery goes dead??????????
I was wondering if my key-less battery goes dead how do I get into and start the C6 Thanks
Old 11-04-2009, 11:11 PM
Tommy D
Tommy D's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
You should have a key in the fob which you can open up the trunk (earlier C6 FOBs had a key attached) The key hole is above the rear license plate near the button to open the trunk.
Old 11-04-2009, 11:12 PM
TexasMadMan
TexasMadMan's Avatar
I just got my C6 vert last week. I read the 480 page owners manual. I will try to remember what I read. Use your key to get into the rear hatch. Pull the cable to open the door. Place the key fob into the slot in glove box. That's about all I remember. I suspect someone that has owned their car longer than a week can add more.
Old 11-04-2009, 11:26 PM
Vette5.5
Vette5.5's Avatar
Why sweat it, as the #2032 fob batteries are pretty common stock at your local hardware for about $3 or 4 buck's. They should last about 3 years or so, but if uncomfortable replace them more often. The fob's are not easy to open though, and basically need to be jumped on to close again. Just replaced my fob's 2032's and didn't need to reprogram anything.
Old 11-05-2009, 12:05 AM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Keep 1 or 2 extra batteries handy.
Old 11-05-2009, 12:16 AM
Cyber2010
Cyber2010's Avatar
This is correct...Traditional key inside the fob, get into the trunk, pull hatch for door (also hatch for gas), open glove box and there is a tiny little cradle (which is extremely hard to find) that supplies external power to the fob, activating the proximity sensor, allowing you to start the vehicle.
Old 11-05-2009, 12:24 PM
icedancer
icedancer's Avatar
CI 6-7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09
Owner's manual is your friend.
Old 11-05-2009, 12:28 PM
-CM-
-CM-'s Avatar
R t f m
Old 11-05-2009, 01:45 PM
RadarP3C
RadarP3C's Avatar
All the above is correct. The only info I can add is that when the door is opened by the pull cable, your car alarm will sound since the fob wasn't used to open the door and deactivate the alarm.
Old 11-05-2009, 02:04 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
I see that your C6 is a 06. It should have a separate key, from the FOB. Only the 08, 09 and 10's have the key that is stored inside the FOB. If you don't have a key, need to visit your dealer so they can use your VIN to cut you a couple. If you have a key, there is a lock above the license plate that will open the hatchback(or trunk on a vert). On the left side you will find a cable that will open the Drivers door. Then place the dead GOB in the slot in the glove compartment to start the car, using the start button, of course.
Old 11-05-2009, 02:10 PM
CO Lightfoot
CO Lightfoot's Avatar
If you've never done it, try using the key to manually open the hatch. It may require a firm twist the first time. It should get easier after you've done it a couple times.
Using the key will likely activate the alarm (VERY annoying at 2:00 am).
Also, consider making a spare key. I keep one in my wallet. About $5 at most key-making places. Use key blank B106.
Old 11-05-2009, 02:26 PM
TexasMadMan
CO Lightfoot:
If you only have a spare key and not the FOB, would you still be able to start the car?
Old 11-05-2009, 02:29 PM
RadarP3C
RadarP3C's Avatar
CO Lightfoot:
Nope.
Old 11-05-2009, 02:31 PM
StanNH
StanNH's Avatar
Received 1,220 Likes on 410 Posts
CO Lightfoot:
Just do what they do on TV all the time. Pull a couple of wires down from under the dashboard, short them together so they spark and VAROOM! ... off you go.
Old 11-05-2009, 07:13 PM
JoesC5
JoesC5's Avatar
Easier then that, I used to hot wire my friend's Jeep station wagon(late 50's model) using chewing gum foil wrapper wadded up and stuffed between the lugs at the back of the ignition switch. No need to pull wires or cut wires.
Old 11-05-2009, 08:43 PM
CO Lightfoot
CO Lightfoot:
No. The push-button ignition won't work without the FOB. But you can sit behind the wheel and make "vrooom vrooom" noises. And you'll have an audience because manually opening the hatch & door activates the alarm.
Hopefully the alarm stops when you put the FOB in the glovebox slot, but I've never tried it.
I suggested the spare-key-in-the-wallet because of a "dead zone" in the hatch area, where the car does not detect the FOB. If you keep your FOB in a coat or briefcase or whatever, and you put it in the hatch area, there have been reports of the car locking itself when you exit the vehicle... then, without a key or another FOB, you're locked out.
These and other issues are history when the totally-retro split-window C7 debuts with a real ignition key, manual-adjust seats, hand-crank windows, vinyl interior, 2-speaker radio, whip antenna, sealed-beam headlights, high-profile whitewalls, lever-action shocks, and your choice of a Muncie stick shift or Powerglide auto.
Ah, the good old days.
Old 11-06-2009, 08:05 AM
RadarP3C
RadarP3C's Avatar
If you open the hatch with the key, the alarm will not activate.
When the door opens with the pull cable located in the left side of the hatch area, the alarm activates because the car doesn't know the fob is near by since the fob battery is dead. You can turn off the alarm when you put the fob in the glove box slot and start the car.
To If key less battery goes dead??????????
Old 11-06-2009, 11:14 AM
1955 copper
2015 C1 of Year
Thanks to all that responed , you guys are great
Old 11-06-2009, 03:05 PM
Vette Jockey
Roadster Madness. 😠
Vette Jockey's Avatar
Received 1,510 Likes on 864 Posts
St. Jude Donor '13, '20-'21
I keep an extra battery in the glove box, they are lithium so they last forever.
Old 11-06-2009, 04:16 PM
myquickZ06
myquickZ06's Avatar
Is'nt there a place to put the key in the glove box?
Quick Reply: If key less battery goes dead??????????
