Help me please!!!
Old Nov 21, 2009 | 08:06 PM
$howstopper's Avatar
$howstopper
Cruising
Default Help me please!!!
A friend and i was changing the postive battery cable, he told me to pull up to the light before he fully disconnected the cable, so i dropped the hood and didn't relize he had already disconnected it. how do i get in to my car to pop the hood? foolishly he left the key on the arm rest, and my fob won't do the trick because no power. i need help on what to do and fast.
Old Nov 21, 2009 | 08:13 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I believe, the easiest way would be to use the key and open the back hatch (then pull the emergency door release).
Old Nov 21, 2009 | 08:15 PM
Vette_DD's Avatar
Vette_DD
No key (see below)
You'd better start looking for the 2nd key.
Old Nov 21, 2009 | 08:32 PM
$howstopper
Cruising
those are the only to keys that i have.. any idea on what should i do now?
Old Nov 21, 2009 | 08:37 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Break a window, and make your friend pay to have it replaced.
Old Nov 21, 2009 | 08:41 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
dealer mon. morning.
Old Nov 21, 2009 | 09:49 PM
VET4LES's Avatar
VET4LES
Hook a battery charger up to the starter solenoid and see if it might power up the system enough to open the door.
Hopefully the cable at the battery end is not laying on a ground.
Old Nov 21, 2009 | 09:57 PM
vettedoogie's Avatar
vettedoogie
That won't work if you don't have the fob and probably not if the battery cable isn't attached. I hope you have another key.
Old Nov 21, 2009 | 09:59 PM
VET4LES's Avatar
VET4LES
Originally Posted by vettedoogie
That won't work if you don't have the fob.
Your right. What if the doors weren't locked when the battery was disconnected?
Old Nov 21, 2009 | 10:00 PM
da vette guy's Avatar
da vette guy
it's in the car,why not? also he has the fob but not the key(or did i miss something)
Old Nov 21, 2009 | 10:05 PM
$howstopper
Cruising
i have the fob, just not the key. will it work?
Old Nov 21, 2009 | 10:09 PM
VET4LES's Avatar
VET4LES
It should if the battery cable end doesn't short out on a ground. You could do serious damage if it does.
Old Nov 21, 2009 | 10:11 PM
$howstopper
Cruising
thanks, im gonna try it. what should i use? can i use another car or truck?
Old Nov 21, 2009 | 10:21 PM
Kerry G's Avatar
Kerry G
St. Jude Donor '08-'09
Old Nov 22, 2009 | 12:07 AM
vettedoogie
I've seen write ups here where people are able to lock their fobs in their Vettes...I've never done that myself cause I ALWAYS have a fob and key in my pocket or wallet.
Old Nov 22, 2009 | 12:24 AM
DAS ZED's Avatar
DAS ZED
I've seen a tool in catalogs that allows you to reach under the hood and manually pull the latch. It is intended for broken release cables. I don't know if they make one for the C6 though.
Old Nov 22, 2009 | 12:35 AM
Restroom's Avatar
Restroom
Forgive me if I haven't stepped in this particular line of thought before with Vettes, but shouldn't any competent locksmith be able to grant you access any number of ways for a lot less than the price of repairs should anything so far suggested go wrong?
Also, invest in a stout, full-spin chassis rotisserie and several very strong friends. You could then extract the keys like shaking coins out of a piggy bank, and the video would amuse your friends for generations.
To Help me please!!!
Old Nov 22, 2009 | 12:38 AM
Shortimer's Avatar
Shortimer
Sorry you're having this probelm. I'm gonna have a duplicate rear hatch key made on Monday!
Old Nov 22, 2009 | 07:38 AM
rws.1's Avatar
rws.1
Have the dealership make you a replacement key from your VIN #
Old Nov 22, 2009 | 08:06 AM
Marc V.'s Avatar
Marc V.
Usually you will need proof of ownership and photo ID. This is a security measure so that not just anyone can go to the dealership and get a key made with just VIN#.
