c6 (09) headlight moisture ??
I have a new 09 with 1500 miles on it.. I noticed today when I washed it (40*) that there is alittle bit of foggy condensation inside the headlights. Both headlights seem to get this way. The foggy-ness clears up and there is no moisture inside the headlights. But wondering if other people see this look in their headlights.. IS this normal? thanks in advance! Tonya .
SUPPORT AUTISM
Believe it or not it is NORMAL, I had the same problem and panicked. There is a thread here somewhere ir regards to your question.
And dust gets in as well..
You might want to take the cover off the inside wheel well and check the rubber seal over the high and low beam bulbs. I had the same problem on the passenger side and when I recently replaced the bulbs found one of the rubber caps over the light was off.
Red Cell.
And you retrieved a 2.5 year old thread to tell us about it?
http://forums.corvetteforum.com/foru...s-or-more.html
