Dead Battery Charging and Fast Beeps
I have a 2005 and owned it since new. I have never had a dead battery. It had been a while since I last started the car but when I went to get in the red lock light wasn't flashing or even lit. I knew that I had a dead battery. I figured that I could recharge but when I put the trickle charger on the battery it made successive fast beeps. What is the issue won't the battery take a charge because it is too dead? Once I heard the beeps I immediately disengaged the charger. What can anyone recommend I searched and did not find a similar issue with the beeping and all? I appreciate anyone's help...
ah...
If it were ME.... I would just replace it and thank the 4-5 years of use I had with it... It is no doubt weak and time has come to just replace. I don't want to guess, IF it will start... My .02
Tried the Battery Charger Test
I found that my charger did spark. I guess that the battery is too dead. I will go out and replace since it is on it's fifth year. Many thanks for the fast responce. I appreciate this forum's advice I usually find everyone helpful.
Trickle chargers are designed to "maintain" a charged battery. If your battery is dead your best bet is to put a real battery charger on it and see if you can bring it back to life, however i foresee a new battery in your near future.
George
George
Beeps with standard charger
Thanks for the info but when I put on my standard charger I got successive louder beeps. What does the beeping mean? Is the battery too low to accept a charge? I am not a electrical engineer but when the horn beeps I do not take that as a good sign.
The same thing happened to me last year. I had to disconnect the battery to charge it. I bought a new one in the spring, since that one had fully discharged, and I didn't trust it. The dealer said that it tested good though, but I still bought a new Delco.
