Battery "NUTS"
Old Mar 7, 2010 | 09:10 PM
T's C6's Avatar
T's C6
Active Streak: 90 Days
Default Battery "NUTS"
No this is not a dead battery post, today it was raining so I put some wax etc on her and was going to plug in my C-Tek and cover it back up when I noticed that the positive cable was corroding. I took it off cleaned it and reinstalled, then noticed that it would not tighten down. When I installed my C-Tek to the post I lost one of the nuts and replaced it with a regular nut, thus the reason for it being loose, The nuts on the clamps are ex-cave on the bottom so that they will tighten the clamp. There is no place that I know of to get those "NUTS" except dealer or mail order. So the brain started to go into overdrive and I thought that they looked like a feral for a brass air coupling, so I found a 1/4" feral and put it under the nut and glory be it worked. Moral of the story is if you can not make it work you can Obama it.
Please do not say PR&C
