keyfob...
Old Mar 10, 2010 | 02:51 AM
RollinThunder01's Avatar
RollinThunder01
Cruising
Default keyfob...
I have an 07 and my buddy just got a 10 grand sport, Its fob is really different from mine and looks way better, Is it possible to get this fob programmed to my 07? Thanks.
Old Mar 10, 2010 | 04:46 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Yes
Old Mar 10, 2010 | 08:19 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Yes but it is expensive and VERY expensive if you want the key in it to work. http://forums.corvetteforum.com/c6-c...-question.html
I prefer the older FOB because they make soft covers for it. http://www.southerncarparts.com/corv...ket-p-277.html
Old Mar 10, 2010 | 03:19 PM
RollinThunder01
Cruising
how does the key work? is it switch blade like the camaro?
Old Mar 10, 2010 | 03:30 PM
cclive's Avatar
cclive
The key fits inside that new fob. The handle for the key is the metal part at the end of the fob.
Not switchblade...slides into the fob and snaps.
Old Mar 10, 2010 | 03:47 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
For a 2007 it will be a direct swap. You will just need to buy the 2008-2010 fob and key blank, have the key cut for your car and program the new fob (make sure you program it as your primary fob, erasing the old fobs and starting from scratch, or else it will simply add it as fob #3 and it won't work with your memory features as fob #3.
Since that new style fob was originally scheduled to be released for 2007 the lock cylinders are designed to work with the new key.
Prior to 2007 models you would need to add the new lock cylinder for the glove box and rear hatch because the new style key will not work with the old style cylinders.
Here is a photo of the 2008 keyfob design. The key is attached to silver metal portion at the top (bottom in this photo) and snaps inside the fob when not in use.
Old Mar 10, 2010 | 04:08 PM
lawnmore's Avatar
lawnmore
Outstanding reply
Old Mar 10, 2010 | 04:12 PM
cclive's Avatar
cclive
Paul,
Mine is a very late '07 and the metal key has a 'full width' section in the middle of the key, so I was under the impression that it would not work since the '08 key blank is not wide enough to have that 'full width' cut.....information only, as I like the '07 fob better anyway...but I just thought I would mention it.
Old Mar 10, 2010 | 04:50 PM
talon90's Avatar
talon90
NCM Ambassador
Originally Posted by cclive
Paul,
I'm just passing along what the GM engineers told me when I asked them. I have an '05 so I've never tried it.
Old Mar 10, 2010 | 04:55 PM
LS WON's Avatar
LS WON
Those little color FOB protectors work well. One of my remotes is loose from trying to open it. Had a very hard time and left big indentions on side of FOB so it doesn't snap back together without having the rubber FOB case covering it. It holds the FOB together.
Old Mar 10, 2010 | 05:11 PM
Vette5.5's Avatar
Vette5.5
I've got no problem with my 06' fob, especially since I rarely even look at it. When taking the Vette, toss it in my pocket. When returning home, back in the drawer it goes. My house key's are on a seperate ring than the car fob's, so it's easy to swap car's without all the extra stuff jangling around.
Old Mar 10, 2010 | 08:45 PM
Bone Daddy's Avatar
Bone Daddy
Member: Jr Geezer's Club
Give it another year and there will be yet another one.
Old Mar 10, 2010 | 09:35 PM
cclive's Avatar
cclive
Bingo, that's what the designers intended. Mine could be a fob with no buttons at all. Never use any of them. It's a great system!
Old Mar 10, 2010 | 09:51 PM
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
The key inside the fob was a great idea, but the new flat fob always gets a button pushed when I get out of the car. (until I remember to put in it a coat pocket). I think I liked the fatter fob better.
Old Mar 10, 2010 | 09:59 PM
cclive's Avatar
cclive
I've heard of this problem with the new fobs...I think I would disable all the buttons on at least one of my fobs if I had the newer style.
Old Mar 10, 2010 | 10:01 PM
LS WON's Avatar
LS WON
I do the same here don't use those buttons and I like this old FOB as it looks smaller than the new fancy one. I hate having my pockets full so the less space and smaller the better.
Old Mar 10, 2010 | 11:16 PM
cclive's Avatar
cclive
To keyfob...
Old Mar 10, 2010 | 11:26 PM
danl72's Avatar
danl72
2010's Vettes have remote start as well.
Vehicle Key Features
1LT 2LT 3LT 4LT
Keyless Access with Push-Button Start
Standard
Old Mar 10, 2010 | 11:32 PM
cclive's Avatar
cclive
1LT 2LT 3LT 4LT
Standard
Except the push-button is on the dash...not on the fob. Same since 2005
Old Mar 10, 2010 | 11:45 PM
danl72's Avatar
danl72
Opps, you are correct. I read somewhere that they wanted to add remote start.
