Vibration or Wind noise in 2008 C6
Old 10-19-2014, 01:18 AM
  #101
ProfessorDeath
ProfessorDeath's Avatar
St. Jude Donor '13-'14
Sometimes the cowl will vibrate against the windshield. Check into wedging something in there first.
edit: I see this is resolved. Good to hear.
Old 10-30-2015, 07:31 AM
  #102
rcurotte
2nd Gear
rcurotte's Avatar
Bought a 2008 Corvette Coupe in May of this year(2015) The vibration started the day that I bought it. The dealer has tried to stop it numerous times, but with no luck.
Glad to see that I'm not the only one who experienced the irritating noise. I'm going to try the black electrician's tape on the plastic cowl to see if it stops it. Thanks to everyone on this forum for sharing there thoughts and solutions!!
Old 10-30-2015, 08:40 AM
  #103
Arkay
Arkay's Avatar
The tape trick confirmed the problem on my 2008 but the fix was to take it to my local windshield repair place and the tech sealed the whole cowl (end to end) with some silicon stuff. It has been perfect since he sealed the cowling.
Old 10-30-2015, 03:10 PM
  #104
rcurotte
2nd Gear
rcurotte's Avatar
[QUOTE=Arkay;1590801704]The tape trick confirmed the problem on my 2008 but the fix was to take it to my local windshield repair place and the tech sealed the whole cowl (end to end) with some silicon stuff. It has been perfect since he sealed the cowling.
Thanks for the pic and the information. Unfortunately due to the upcoming winter, I'm having to store my car for the winter. It goes into storage tomorrow. I am definitely going to take it to my local windshield installer in the spring to have it siliconed to see if it fixes the problem. If not, it's going to have to be a new cowl at the dealer.
Old 10-30-2015, 05:06 PM
  #105
cclive
cclive's Avatar
Originally Posted by siggie
I think I found where our problem is. After I washed my C6 wile drying it off with the leaf blower, I ran it over the right side at a slight angle just over the center of the wiper blade and wiper arm.Sure enough the sound came .When I moved the blower to the other side nothing happened . I looked closer as I put the air to the right side again I noticed that the plastic that set's against the window was vibrating.
The bad part is I had to take the vet to the shop for a new rim and have not been able to tape it down to see if it goes away when I go on the Freeway for a test drive . I will check this when I get it back and up date as to what I find.
I put a piece of black electrical tape across the area where the plastic meets the base of the windshield years ago...all the way across the car. It doesn't show and has been very durable...done and done.
Old 10-31-2015, 07:46 AM
  #106
TKrug007
TKrug007's Avatar
[QUOTE=Chevy Cust Svc;1586436732]
Originally Posted by Red08
Hey Red08,
There is not a recall for wind noise on the Corvette. Although I cannot guarantee what the outcome will be, I would be more than happy to look into these concerns further for you. Please private message me your contact information, VIN, and your preferred dealership name/location. I will be looking forward to your response. Thanks!
Jennie R.
Chevrolet Customer Care
I have the same issue with my 2008, it's either a poor material choice or failure, no doubt. Mine occurs regularly above 70 mph.
Tim
Old 01-04-2016, 09:35 AM
  #107
Jake08490
2nd Gear
Jake08490's Avatar
same noise developed in mine also
thanks
would like to hear from
Geoff Allen
Chevrolet Customer Assistance to see what he has to say
Old 01-07-2016, 04:37 PM
  #108
ULOSECLOWN
ULOSECLOWN's Avatar
Default 2009 c6 same rattling problem==help
I am having the same problem i believe it is the windshield cowling but i am not sure .. Very annoying rattling noise when traveling above 70 mph
Originally Posted by chevy cust svc
hello,
sorry to hear that you are experiencing problems with your vehicle. I am going to send you a private message for more information.
Geoff allen
chevrolet customer assistance
Old 01-07-2016, 05:35 PM
  #109
ULOSECLOWN
ULOSECLOWN's Avatar
Default Rattling wind noise/window cowl 70+mph
IS THERE A TSB FOR THE WINDOW COWLING 2009 CORVETTE COUPE?
part #25778761
Originally Posted by Chevy Cust Svc
Please keep us posted on what you find out, if you get the noise quieted down.
Brent
GM Customer Service
IS
Old 01-07-2016, 06:43 PM
  #110
PDsVettes
PDsVettes's Avatar
Here you go.
https://www.corvetteforum.com/forums...l-problem.html
Post #65
Old 04-12-2016, 02:04 PM
  #111
donb12257
2nd Gear
donb12257's Avatar
Default donb12257
I also have the vibration or noise from the passenger side dash on 2008 convertible. started at about 28,000 miles. cannot find anything loose to rattle. starts at speeds around 55. its like there could be a vent door somewhere but cannot find it. very frustrating while driving. sounds like its at the bottom of the A pillar. tried masking tape to the fender/door gap. covered the fender cove. no change.
Old 04-12-2016, 02:16 PM
  #112
NashvilleGrandSport
NashvilleGrandSport's Avatar
See the post above yours. That fixed my issue as well. Took about 10 minutes. Try it.
Old 04-12-2016, 02:29 PM
  #113
CSF - One
CSF - One's Avatar
Look at the external plastic cowl at the bottom of the windshield. It tends to rip or pull away from the windshield setting up the vibrations you hear from the inside. If that is the problem, then have a new cowl installed and it should go away.
Old 12-01-2017, 08:52 PM
  #114
Russell333
1st Gear
Russell333's Avatar
here is a quick fix.
sunny12 (01-24-2018)
Old 09-14-2018, 01:12 PM
  #115
peterbenson
peterbenson's Avatar
I had the same issue and I used flexshot that is basically silicon in an easy to apply can and works like a charm
Old 09-15-2018, 09:41 AM
  #116
Euthymicone
Euthymicone's Avatar
Originally Posted by TonyFaub
Don't know about replacing the cowl but I put about a 1/8 bead of clear silicone adhesive under the rubber edge where the cowl meets the windshield. I used a damp micro-fiber cloth to smooth out any oozing and remove any excess, let it cure overnight and this past weekend I drove all over NC from Grandfather Mountain west to the Dragon 129 in TN with no issues. Cost me about $3.
Same here. The buzzing was crazy! Searched "cowling or buzzing in dash" and found myriad fixes and pictures on this forum. Sounds like this is a very common problem (along with sticking in park and shifter cable problems. Unfortunately, that fix is not so easy. Maybe the Chevy Cust Svc rep can shed some light on those common problems). Some caulk, electricians tape, and it has been resolved for months so far. Will be heading to E. NC and Biltmore/Blueridge Pkwy for a true test next week.
Old 09-15-2018, 01:03 PM
  #117
Flh Den
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
Support Corvetteforum!
Flh Den's Avatar
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I tried the sealant and the black electrical tape and finally just bought a new cowling and replaced it as described in Russell 333's video above. Simple fix. Sold the car eventually anyway.
Quick Reply: Vibration or Wind noise in 2008 C6
