Vibration or Wind noise in 2008 C6
I have a frustrating intermittent vibration or wind noise in the dash of my vette that the service techs can't resolve because they can't duplicate the problem. Happens at different speeds, but mostly when traveling around 70-80 MPH. Sounds like a fairly loud hummm coming from either the top center vent or from somewhere inside the dash on the passenger side. Strong winds quartering into the front right side of the car seems to make it worse...as does certain road surface types. Of course everytime I take service tech for a ride to show him the problem...nothing happens -- very frustrating. Have any of you had a similar problem and found the cause? Thanks for any insights you can shed on this nagging issue.
Sorry to hear that you are experiencing problems with your vehicle. I am going to send you a private message for more information.
Geoff Allen
Chevrolet Customer Assistance
OP you are not alone...Ditto on my 08
Wasn't there a TSB out about this issue being caused by a faulty piece in the window mount or trim?
I can't complain about the wind noise in my 08 C6. If I left the M2W in its off position I probably would be up to triple digits without knowing it, besides the tire roar that is. I wish they would put Michelins on all Corvettes. I haven't found a GY tire that I liked yet.
I has a intermittent buzz at low speed over bumps it was the glove compartment door, if you close the door harder than normal it would go away but come back a few min later, I think it was slight play in the lock striker or the glove compt. door.
I traded the car before I got a chance to look into it, try opening and closing the glove compt. door when you hear the noise see if it make a difference.
Good luck
Same problem here.
Same here ^, I just keep my M2W on wild and I don't here a thing!
The bad part is I had to take the vet to the shop for a new rim and have not been able to tape it down to see if it goes away when I go on the Freeway for a test drive . I will check this when I get it back and up date as to what I find.
If this is an answer to the problem can you please make it public? No offense but this is a bit of BS. If GM has a solution they should make it public IMHO. Please PM me also with the solution if thats the way it has to be. Thanks.
had same problem with my car 2 years ago drove me nuts.....placed duct tape on cowl and windshield took car for a ride on hwy.....no more noise replaced windshield cowl...i guess it warps aftertime
Please Advise
Good post.....some Z owners had close to the same problem,,,but on some it turned out to be the oil "O" ring that was split on the dry sump can..glad there is another fix....
Is there a TSB # on this?
I have the same humming vibration....worse upon acceleration.
