Sway Bar End Links
Sway Bar End Links
Hey Guys,
My squeaky/creaking sway bar end links are acting up again. I got rid of the creakk by just greasing them in the past, but the noise is back again and I'm thinking of just replacing them. Where is the best place to buy new end links??
Thanks for the help as always.
This is what I did and can't say enough good about doing it. I had replaced the stock ones 3 times and it still popped. But after putting these on it is quiet at last. Look at post #3 and she will fix you up. hope this helps
St. Jude Donor '10
I replaced mine with the LGs as well when I upgraded to Z51 bars. Mine were sqeaking also prior. Totatlly quiet now.
I just installed my new end links, purchased from MTI, and I still have the "end link klunk". I adjusted them to the exact same length as the original stock ones, so I'm beginning to suspect I may have a different issue??
get my used LGs, i went with PFADT Competition sways which include their end links
they are as good as new
http://forums.corvetteforum.com/c6-p...post1573101098
Premium Supporting Vendor
The revised 2010 end links have been developed to dismiss the noise and rattling issue. If anyone is interested in the GM end links let me know.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
My '08 F55 has a light metallic popping sound, mostly at low speed in parking lots. It seems to happen when weight shifts from one side of the car to the other.
Do you guys think the LG Motorsports end links would get rid of the noise? (I've already tried changing the differential fluid to Dexron LS and that didn't help).
Also, LG Motorsports has a funny typo in their website's product description:
"LG Motorsports took the GM end links one setup farther ..."
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I have the recent upgraded GM end links and the car has never been so quite. I am still holding my breath though, only have a few hundred miles on them.
Went through the stock set around 10K miles, the second GM set about 15K miles.
Give it time, the popping will be back with the factory links.
