Lug Nut Torque Specs?
Yea, thats fine.. but How are you going to check the accuracy of the Torque Wrench??
90% of vibration is gone.
IDK you have just blown my mind... I must call out of work all week while I figure this riddle/puzzle out !!!!?
Received 2,049 Likes
St. Jude Donor '13
Some shops will calibrate the wrench for you. Snap On will check/calibrate their own ones.
Or you can get a beam-type wrench (shouldn't ever go out of adjustment) and make a double female fitting. See what the beam says when your adjustable clicks at the different settings. Then sell me a duplicate fitting so i can check my own wrench.
You mount the torque wrench so the axis of rotation is parallel to the floor and ONLY the square drive is being held in a vice (or, put a large socket in the vice and attach the wrench to it). Measure a spot on the handle of the torque wrench (let's say 18", aka 1.5 ft.) away from the center of the square drive - mark that spot. Make sure the wrench is set to 'tighten' and rotate it so the handle is parallel to the floor. Now find a weight that you can suspend (hang) from the handle - preferably something heavy that would take the wrench to the middle of it's operating range. Set the wrench torque = weight x 1.5 ft/lbs. Now hang the weight. It should click at that setting or very close to it - you would back off 1 ft/lb or add 1 ft/lb to find what the limits are.
Actually I have heard that is the way to do it.
That's why I take me wheels off at home and take them to the shop. As I have said many times on this forum there is only one way to know it's done right and that's to do it your self.
Get Some!
gliderdriver (06-05-2022)
St. Jude Donor '13
Wheel nuts are obviously ok for multiple uses, and the torque specs are low enough to prevent any permanent distortion.
An engineer once told me that engine and braking force is transferred from the hub to the wheel by the clamping force of the studs/nuts that are properly torqued, not by the shear strength of the studs.
BTW, most fastener torque values are for dry threads, any oil or anti-seize will act as a lubricant and the normal numbers will actually be an over-torque.
#33
Ok, reviving old thread. If you put aftermarket wheels on your car, do you go by manufacturer recommendation, or by the aftermarket wheel manufacturer recommendation? Or by the tuner lug nut recommendation?
#34
I was I the dealership last week and I can confirm it is 100 pounds
#35
The "correct" term is pound/feet (LB/FT). But we get ft/lb, feet, pounds, gallons, or sheep. Just follow at the numbers on the wrench. My ideal is 93.
#36
Received 1,636 Likes
Am I the only person that tightens lug nuts by hand until I come to the conclusion that this feels like a 100 ft/lbs?
#37
Received 2,683 Likes
2018 C6 of Year Finalist
#38
Received 4,707 Likes
No one has mentioned it here yet, but the answer is 100ft lbs
#40
Make certain the torque wrench is “ dead on ***** “ accurate.
