Will a VIN tell me how a car was equipped?
I apologize if this is a dumb question.
Is there an easy way to tell how a car was originally equipped using the VIN number?
There's a car I'm interested in buying and I'd like to know what options it came with.
Thanks in advance.
Thanks in advance.
http://www.compnine.com/vid.php
Type in the VIN and you should have the factory installed options. I believe the colors were all listed in grey. They may have changed that.
It gives you the rarity of the factory optioned car, too.
St. Jude Donor '06-'07-'08-'09-'10,'14
Yes, it is possible. The easiest way if you have access to the car is to open up the glove box and look at the tag to the left that has all the 3-digits codes. Copy them all down and you can decode what came on the care. If you don't have access to the car you can send the VIN to a couple of people here and they can run it through the GMVIS system and get you the same info plus a lot more. I know GMautotech got me mine a while back. Possibly partstaxi or gmpartshouse may be able to help.
Former Vendor
GM Vehicle Inquiry System
Vehicle Build
Home - Summary - Claim History - Vehicle Build - Vehicle Component - Delivery Information - Dealer Information - Service Contract - Warranty Block - Branded Title
Help
VIN 1G1YY34U855135062
VEHICLE BUILD
Merchandising Model : 1YY67 -2005 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1673 kg (3689 lb) Order Number : JGKGBV
Build Date : 08/22/2005 Build Plant : 155Y
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AAB - MEMORY PACKAGE AJ7 - AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE CM7 - POWER CONVERTIBLE TOP
DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - 50-STATE EMISSIONS G90 - REAR AXLE-3.15 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
KA1 - HEATED SEATS K63 - 110 AMP GENERATOR
LS2 - 6.0 LITER SFI V8 - 400 HP MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M32 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NK4 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
QG7 - POLISHED ALUMINUM WHEELS SLM - STOCK ORDERS
UE1 - ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND UG1 - HOMELINK TRANSMITTER
UJ9 - LOW TIRE PRESS. INDICATOR URB - AM/FM CD WITH DVD NAVIGATION, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO)
US3 - ANTENNA DIVERSITY UV6 - HEAD UP DISPLAY
U2K - XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL U52 - ELECTRONIC INSTRUMENTATION
U65 - SPEAKER SYSTEM 7, PREMIUM VA5 - ENGLISH LANGUAGE LABEL
VDD - VEHICLE INFORMATION DVD VK3 - LICENSE PLATE BRACKET
VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XFV - FRONT TIRE - P245/40ZR18 YFX - REAR TIRE - P285/35ZR19
1SB - PREFERRED EQUIPMENT GROUP HEAD UP DISPLAY HOMELINK TRANSMITTER MEMORY PACKAGE AUTO DIMMING ISRV MIRROR W/COMPASS & DRIVER OSRV MIRROR HEATED SEATS RDS AM/FM STEREO W/6-DISC IN DASH CD W/MP3 PLAYBACK, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO) PWR TELESCOPING STEERING 1SZ - PREFERRED EQUIPMENT SAVINGS
31I - LT CASHMERE INTERIOR TRIM 313 - CASHMERE LEATHER TRIM SEATING
35T - TOP - BEIGE 41U - BLACK
© 2009 General Motors. All Rights Reserved.
Vehicle Build
Help
VEHICLE BUILD
OPTION CODES
Moderator
Received 3,576 Likes
I did mine:
"There are 1 2006 CORVETTE CONVERTIBLE vehicles (0.009%) matching your exact options list."
No. By itself, the VIN will not tell you how it's equipped. It will tell you the body style and which engine it has. That's about all.
However, if someone who has access (like PartsTaxi.com) to the GM VIS looks it up on that system, it will tell you quite a bit, as indicated above.
This is an example of a VIN # for a 2006 Corvette Coupe:
1 G 1 Y Y 2 6 U 3 6 5 1 0 0 0 0 1
There are 17 characters. Starting with first character on left the codes are:
1. "1"= Built in US
2. "G"= General Motors
3. "1"= Chevrolet
4. Denotes the car line: Corvette is a "Y" body.
5. Provides more info about the car:
Usually a "Y" but the ZR-1 is "Z"
6. Body style: "1" = FRC, "2" = Coupe, "3" = Convertible
7. Restraint code
8. Engine:
L98="8"
LT1="P"
ZR1="J"
LT4="5"
LS1="G"
LS6="S”
LS2=”U”
LS3=”W”
LS7=”E”
9. Check Digit – 0 to 9 or X
10. Model year:
"B" thru "N" are yrs '81-'92 respectively
"P"='93
"R" thru "T" '94-'96
"V"='97
"W"='98
"X"='99
"Y"='00
"1"='01
“5”=’05
“6”=’06
“7”=’07
11. Plant: Bowling Green = "5"
12-17. Production sequence number that starts with the #1 for each model yr.
1. "1"= Built in US
3. "1"= Chevrolet
7. Restraint code
8. Engine:
L98="8"
LT1="P"
ZR1="J"
LT4="5"
LS1="G"
LS6="S”
LS2=”U”
LS3=”W”
LS7=”E”
10. Model year:
"P"='93
"V"='97
"W"='98
"X"='99
"Y"='00
"1"='01
“5”=’05
“6”=’06
“7”=’07
Still I like the site overall, they just need to tweak it a little ...
1G1YY24U955102341
That was interesting - - it said Unknown build date and nothing about color . . .
I know it was delivered Sept 22, 2004 and is one of 1274 Precision Red coupes . . .
1G1YY24U955102341
I know it was delivered Sept 22, 2004 and is one of 1074 Precision Red coupes . . .
purchasing a used c7
Hi wanted to know if anyone can help me and send me the list of options that this car has, as i have sent them the money to purchase it.
Vin:1G1YL3D70E5114246
original equipment for VIN #1GKET66M266140264
Wow, you guys are great. My vin # is 1G1YY24U755116996
fourth vette (01-22-2017)
C7 option via VIN
I'm looking at a used C7 at Carmax. They've been unable to help me with the options ordered with the car. The VIN is:
1G1YJ2D71G5102495
I'd really appreciate any help y'all can provide.
1G1YJ2D71G5102495
