Celebrate Memorial Day with 10% off all Exhaust Commander NPP exhaust controllers!
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
This Memorial Day - 10% off all Exhaust Commander NPP exhaust controllers!
USE Coupon code " memorial10 " at checkout to get an additional 10% off ANY Sunset Orange Creations product. Sale ends Monday at midnight!
I have introduced many new innovations in bi-mode exhaust controls over the years. User selectable rpm opening, ZERO Battery Drain remembers last setting mode, Dash DIC button control, and Navigation address entry unlock with the C6 Navigation Commander.
And now the new Lear car2u visor compatible Exhaust Commander that works with your universal visor on your 2006-2010 cars! No Fobs needed!
Below are the descriptions of the different Commander controller models, click on the name to go to my online store to purchase one:
Click here to purchase --->Lear Car2U visor compatible Exhaust Commander
Introducing the new Lear Car2U visor compatible Exhaust Commander One Button Wireless NPP/Z06/ZR1 exhaust controller! For sale in my online store and ready to Command your NPP, Z06 or ZR1 Bi-mode Exhaust from one button on your 2006-2010 Lear Car2U visor! No Fobs Needed!
I offered the first version of my Exhaust Commander One Button wireless NPP/Z06 exhaust controller unit for sale 2 years ago. Now here is the Lear Car2U visor compatible Exhaust Commander unit. No Fobs Needed!
You get the 2006-2010 Lear Car2U visor compatible Exhaust Commander main control unit.
The install instructions are available as a PDF file to download at http://www.sunsetorangecreations.com/Instructions.php so you can view the instructions on any computer.
No Fobs are needed to open and close your exhaust from inside the car, just one button on your Car2U universal visor.
You can have a keyfob remote added as an option if you would like to be able to open and close the exhaust from outside the car, but it is not needed for install or normal operation from the visor.
Take Command of you NPP, Z06 and ZR1 exhaust, you get to choose whether the exhaust is Quiet and mellow, and you also get to Command it to be Loud and mean when you want it.
Open and close your exhaust with ONE button on your Lear Car2U visor or with an optional One button Keyfob remote. Switch between Quiet and Loud anytime at the push of a button!
You press the button on the Car2U visor or keyfob remote once, the valves in the bi-mode mufflers close and you have the quiet factory operation mode, nice and quiet and opening at the factory rpm, press the button again, the valves open and you are in Loud mode and ready to rumble! Exhaust Commander is 100% Zero Battery Drain when the car is turned off.
Click here to purchase --->C6 Navigation Commander
C6 Navigation Commander allows address entry, searching points of interest, Nav setup changes, and access to stored destinations, all while on the move and it does not timeout and lock you out! If your going to install a PAL iPod interface you should get this controller and install it at the same time since you have to take the console off and access the NAV unit. Here is the thread with a detailed description.
See the Video below to show how it refreshes and doesnt lock out.
Click here to purchase --->Exhaust Commander One Button NPP / Z06 Wireless Exhaust Switch
This is the Exhaust Commander One Button Wireless NPP On / Off switch. Only ONE button is needed for switching between Loud and Quiet modes. You press the button on the Fob once, the valves open, you press it again, the valves close again.
There is ZERO DRAIN on the battery when the car is off. The butterfly valves can start in any position, open or closed and you choose when you install it and can change it at any time.
This kit gives you the ability to open or close the NPP / ZR1 or Z06 butterfly valves using a One button wireless remote.
The install only takes 3 minutes to complete and can be removed just as easy without a trace. The only tool needed a 7mm nutdriver or socket. The option to purchase a 7mm nutdriver is also available if you dont have one already to do your install.
Kit includes a wireless receiver switch and Keychain One button wireless remote. This unit is not compatible with the 2006-2010 Lear car2u universal visor remote.
Click here to purchase --->Exhaust Commander D.A.S.H.
This is the revolutionary new Exhaust Commander D.A.S.H. NPP/Z06/ZR1 Bi-mode exhaust controller.
Exhaust Commander D.A.S.H. allows you to control your bi-mode exhaust with your dash D.I.C. reset button and also control your exhaust with a wireless remote! The Exhaust Commander D.A.S.H is the first bi-mode exhaust controller to allow both wireless and dash button control of your exhaust!
With this plug and play controller you get the revolutionary new feature of being able to open and close your bi-mode exhaust butterflies right from your dash D.I.C reset button! Using the dash D.I.C. button means that while driving and changing your exhaust back and forth from Quiet to Loud you dont have to look for a remote to do it. The D.I.C. button is 2 inches from your finger!
This controller also comes with a wireless remote so you can operate your exhaust from outside the car to show all of your friends how sweet it is to have total control of you bi-mode exhaust, both inside and outside your car!
This product is 100% ZERO Battery Drain when the car is turned off and has the Zero Battery Drain Remembers last setting mode at the same time!
Here is the thread with the install instructions --> D.A.S.H. Install Instructions
Here are the revolutionary features of this controller:
You can control your NPP/Z06/ZR1 bi-mode exhaust from your dash D.I.C. button, or use the supplied wireless remote to control your bi-mode exhaust.
This product is 100% Zero Battery drain and also has the Zero Battery drain remembers last setting feature built in so the mode you shut the car off in is the mode it starts up in.
This product is plug and play and no permanent modifications need to be made to the car to use it. If you choose to remove it at a later time there will be no trace that it was ever there! Just plug in the power fuse adapter, the exhaust signal wire to the exhaust fuse location, bolt down the ground ring, and hookup the D.I.C. dash button sensor to the D.I.C. button connector and your done. Typical install time is 15 minutes.
The Kit includes the Exhaust Commander D.A.S.H. main unit, a wireless keyfob remote. The install instructions are available as a PDF file to download at http://www.sunsetorangecreations.com/Instructions.php so you can view the instructions on any computer.
This Product works on any 08-2010 NPP Bi-Mode Exhaust system or ZR1 / Z06 Bi-Mode Exhaust system.
Click here to purchase-->
Exhaust Commander All-in-1 NPP Bi-mode exhaust retrofit kit
This kit includes the wireless controller with a one button keyfob remote, and all of the necessary vacuum lines, vacuum solenoid and wiring to complete the control system installation on a C6 that is retrofitting bi-mode exhaust.
It will give you full open / full closed modes and gives you the ability to switch between the modes instantly using the supplied One button wireless remote.
You can have the car start and the butterflies remain open until you close them, or you can have the car start and then the butterflies close until you open them. And can switch between open and closed modes with the One button wireless remote.
The Exhaust Commander All-in-1 NPP retrofit kit has the Zero Battery drain remembers last setting feature built in so the mode you shut the car off in is the mode it starts up in.
This kit uses engine vacuum as the source of vacuum to control the butterflies in the mufflers. The GM recommended vacuum port on the intake manifold is used just like NPP cars, Z06's and ZR1's!
The All-in-1 retrofit kit is now available with the Exhaust Commander D.A.S.H. controller function. This options allows you to control the opening and closing of the exhaust butterflies from the dashboard D.I.C. reset button! Be sure to choose it from the drop down menu!
This All-in-1 retrofit kit is also available with the no splice RPM opening option.
This Product works on any C6 2005-2010.
Take a look at all the controller models I offer and get the one that best suits your needs.
If you need any additional info, let me know.
Click Here -> Exhaust Commander D.A.S.H. the revolutionary new bi-mode exhaust controller!
NPP Bi-mode exhaust vacuum retrofit kits -> Exhaust Commander All-in-1 bi-mode retrofit kit.
My Online Store -> See all my Bi-mode Exhaust Controller Products!
St. Jude Donor '13
Thanks for all the orders!
Have a Safe Memorial Day.
