Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Cleaning and Detailing
- How to Clean Dead Bugs on Bumper
Step by step instructions for do-it-yourselfers.
Dead bugs on bumper...best way to clean them off?
I don't like having a bra on the front bumper. And, the 80 mph dead bug bumper thing is really something else.
I don't want to scratch the chit out of the paint, but they only come off with a lot of elbow grease, which I'm afraid is too hard.
Anyone have a impaled dead bug on your front bumper removal secret?
Received 2,051 Likes
St. Jude Donor '13
I'd say be sure to wash the car before doing anything else, you don't want to be grinding road grit into your paint while removing the bugs.
I've used various bug removers, WD40, Coca Cola, and whoknows what else. A clay bar is said to work well. There will be a big crowd of experts show up soon to help you out!
If they are really bad, and dried on, I soften them up with a rag and warm water followed by a detailer. Most any will do; I use Ibiz or Mequires. Wipe/spray it on, let it sit for a second or two and gently rub off. Corvettes have the softest clear coat in the car business, so you have to use TLC.
1 Post
I use turtle wax "bug and tar remover" I found it at an autozone. Works well, never seemed to have any adverse affect on the paint. claims "safe for all finishes" and "does not strip wax" on it for whatever that's worth.
pwj155 (09-14-2021)
I have used it too and it does work
If you are planning a long trip through bug infested areas, spray some "Pam" on the areas where the bugs build up. Wash it off each night with soap & water and respray it in the morning before you leave.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I've used this before, too. Also, you can just sort of drape (a little hard to do on the front bumper) a very wet towel over it and let the water soak in over a period of 15+ minutes. And then use the detail spray, bug remover, polish, etc.
Try using a wet dryer sheet like Bounce. What is in Bounce is amazing. Once finished then wash off the residue. Works great, especially on love bugs.
AutoCutter (11-30-2017)
The important thing is to make sure it is soaked for as long as possible to loosen things up. I know my parents used to use fabric softener sheets to get off the love bugs when the season came.
I'd quote all these suggestions, because they are all great ideas.
Funny, in the 23 years I've been driving a Vette as a DD, I've never been a car washing kind of guy.
But, once I joined the Forum in Feb., right before I got the LMB 07, I've turned into a very conscious "I want a clean Vette guy".
I've got to say, I love the LMB, but it is by far the darkest blue I've ever had, so shows everything (way worse than the 91 Quasar Blue, and 85 blue).
Well, guys I like the 15 minute rag soaking idea, the Turtle wax bug remover, the WD 40, ,Bounce!, the Pam b4 the drive, the washing the road grit off b4 attacking the bug juice. And, about the Rejex, I have a good coat of Zaino on it, which I would think would be pretty effective... most of it comes off, I think it's those short 90-95 mph impaled bug spurts!
Talk about an incentive out of side of speeding tickets, not to speed!
I have found that soaking a towel in spoapy water and then drapping it over the car so that it lays in contact with the surface for a long period works wonders. long period is an hour or two so that the soapy mix sinks in and loosens things up. Pour more soapy water on it from time to time. With the steep front end on a Vette you might have to fashion a way for the towel to lay against the surface like take another wet towel and put it further up the hood holding the front towel.
Before draping the wet rag (I use old 100% cotton T shirts), I go over the area with a California duster to remove any loose grit. Once the rag(s) are in place, I spray them down with a trigger sprayer filled with deionized filtered water, but ordinary water will do if you don't let it dry before wiping it off. It helps to spray additional water on the wet cloths while the bugs are soaking.
Once the rag has set for 10 - 15 minutes or so, I carefully remove it with a wiping motion and most of the bugs come off with it. Any remaining bugs can be removed by additional wetting. I use my water filled trigger sprayer.
Another tip you might find useful when you get just a very few bug spots, is to use pieces of soft high quality paper towel instead of rags to wet the spots. I know some of the members will scream that this will scratch the clear coat, but I have a black car and I defy you to find any evidence of the technique! Just use the paper towel to wet the bugs and wipe with a micro fiber cloth to remove them. The paper towel brand I use is VIVA.
I have used WD-40, 7-up, Windex, and Honda Cleaner/Polish. The Honda product can be found at motorcycle dealerships. Spray on wait a minute and wipe off. It works well for me. and leaves a protective coating on the area. Oh also I have heard that a mixture of Peroxide will work. As it will eat into the bugs proteins.
TNRC (11-30-2017)
409 baby. use it for the grime behind the wheels and the bugs-- wet paint spray let soak for 5 minutes wash. If anything left on I use Meguires scratch X on it ( any fine wax/polish will do) Has enough abrasive to get stuff off and wont scratch the paint. I always apply a wax of something after to protect the paint
I just wet them down with a wet rag after every drive, then gently wipe them off a couple minutes later and apply a detail spray before the next drive.
I think they are easier to remove if they dont sit on the paint long and dry. And the detail spray keeps the area slick so they dont stick as well.
Must be the people who sold me the high priced Menzerna polishes lied to me. They said it's one of the hardest in the industry....
