low voltage
Old Jul 5, 2010 | 05:29 PM
Tnyce's Avatar
Tnyce
Default low voltage
Need some advice!
I got a new aftermarket crank pulley installed but when the car is idling with the AC and headlights on, the voltage meter goes down to about 12 or lower. Please tell me what I can do to make it charge to the correct voltage. Thanks!!
Old Jul 5, 2010 | 06:35 PM
haljensen's Avatar
haljensen
Put the correct diameter crank pulley back on?
Raise your idle speed?
Old Jul 5, 2010 | 06:58 PM
AlfredMay's Avatar
AlfredMay
Super high output alternator
Old Jul 5, 2010 | 07:02 PM
Robls6's Avatar
Robls6
You're spinning all of your accessories slower than they were designed for. What did you expect to happen?
Old Jul 5, 2010 | 10:04 PM
LMB-C6's Avatar
LMB-C6
I'm not surprised. I've noticed that even a completely stock car when idling and running A/C, lights, the car's cooling fan is on, etc. that the voltage dips into the mid/upper 13's. Now you are spinning the alternator slower under those conditions and you see the end result.
I guess the question I would ask is: Does doing this for brief periods hurt anything? I would just make sure that you drive the car long enough for the battery to fully charge.
Old Jul 5, 2010 | 10:17 PM
cclive's Avatar
cclive
with the above...rules are that you have to spin the alternator fast enough to keep up with the electrical demands of the car....
Old Jul 5, 2010 | 11:14 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
A battery tender/charger is a good investment for you as well.
Old Jul 6, 2010 | 01:14 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Old Jul 6, 2010 | 09:08 AM
kevakasper's Avatar
kevakasper
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
It will start giving you a low voltage warning on the DIC, you have to hit the reset on the gauge pod to get rid of the annoying ringing! One of the reasons I put my car back to stock and eliminated the Mods the previous owner did. There is too much integrated together that a simple mod affects many weird things!
Old Jul 6, 2010 | 09:23 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
So why did you want to run the accessories slower? You decided you wanted to drain less power to run the alternator and now you complain the alternator has too little power? You won't have a problem is you run the engine the way that you should with a smaller crank pulley which is on the track never less than 2500rpm. On the street you are going to have a problem.
I think you need to go back and study the mods you want to make a little more before do them. Everything is a compromise. There is no free lunch. If you try to improve one thing you usually make something else worse.
Old Jul 6, 2010 | 05:48 PM
Tnyce's Avatar
Tnyce
Default low voltage
Yes, thanks! The higher amp alternator crossed my mind but will that solves the problem completely or will it hurt something else?
Old Jul 6, 2010 | 06:00 PM
bolivar's Avatar
bolivar
What is the standard alternator rated at? 150 amps or so?
The problem is - it's turning too slow.
Old Jul 6, 2010 | 08:01 PM
cthusker's Avatar
cthusker
What exactly are you attempting to accomplish with this pulley mod?
Old Jul 7, 2010 | 09:45 AM
FortMorganAl
A higher amp alternator only has bigger wires to handle more current. Since you slowed down how fast the alternator is turning you need an alternator that is designed for the slower speed not just heavier wires. And when you finally find an alternator that gets you back to where you were on how much power it was putting out, you will also be back to where you were on how much power it was taking from the engine defeating a large part of the purpose of the smaller pulley.
Old Jul 7, 2010 | 10:20 AM
BOB EAGAN's Avatar
BOB EAGAN
Need some advice!
Raising the idle speed 100 rpm should solve your problem.
To low voltage
