loose backup light
Old 07-30-2010, 10:31 PM
obone
obone's Avatar
Default loose backup light
Can anyone tell me or better show a picture of how the backup/reverse lights are mounted within the rear diffuser?
Old 07-31-2010, 07:43 AM
obone
obone's Avatar
ttt
Old 08-27-2010, 02:17 PM
rchbn
rchbn's Avatar
I'm looking for the same information. One of my lights looks like it's pushed in at the bottom, but I can't figure out how to get at it to see whats wrong.
Old 08-27-2010, 02:47 PM
RLSebring
Supporting Vendor
Support Corvetteforum!
RLSebring's Avatar
Location: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
2 screws on top of light and tabs on the bottom. May have to unscrew the housing, stick the tabs in then reinsert screws. You can crawl under car or may can reach them through the tail lights.
Old 08-27-2010, 05:06 PM
ALS 08
ALS 08's Avatar
Stick your head up between the mufflers. Well kind of, you can get a glimpse into there though.
Tabs on bottom of lens slip into slots. Not a snug fit so it can wiggle a bit. Screws on top of lens.
Old 08-27-2010, 06:31 PM
Nithros
St. Jude Partner since 89
Nithros's Avatar
St. Jude Donor '09
A friend of mines was loose too on his 08 Z06 and come to find out the tabs were broken off. This sounds crazy but I duct taped it when we had it up in the air putting headers on over a year ago and it's solid as a rock. That's a good fix if that's your issue and you like free.
Old 08-27-2010, 07:50 PM
cclive
cclive's Avatar
Free isn't usually very popular in this forum....usually "most expensive option" is the most popular...
Old 01-17-2013, 04:59 AM
gdaddee
gdaddee's Avatar
Must be common problem. I found one of mine loose at the bottom. Swings as if hinged from the top.
Old 01-17-2013, 05:05 AM
0Airbrush Inc
Former Vendor
Airbrush Inc's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
maybe this will help a little
Old 01-17-2013, 06:21 AM
drich2905
drich2905's Avatar
yep, got the same problem. Bought the car new and it is has always been loose at the bottom. I just left it alone since it doesn't seem to cause a problem. You would never know it unless you push on it.
Old 01-17-2013, 10:03 AM
ALLEN007
ALLEN007's Avatar
Same here.
Old 01-17-2013, 01:01 PM
LS14ME2
LS14ME2's Avatar
Same problem on mine on the driver side. The two little tabs are broken on the bottom.
Rolled up some good sticky duct tape and placed it on the area where it should sit at and seems to be holding pretty good still... No reason to push on it a lot and am careful when washing. So far so good..
To loose backup light
Quick Reply: loose backup light
