GForce Chips
Old Aug 11, 2010 | 03:21 PM
avbump's Avatar
avbump
Default GForce Chips
The ad says: 60 horse power, 4-7 more miles to the gallon & it only cost 69 bucks. ANY members know anything about this product?
website:GForceChips.com
Sounds too good to be true!
Old Aug 11, 2010 | 03:35 PM
cylon's Avatar
cylon
Old Aug 11, 2010 | 03:41 PM
evilmonkey's Avatar
evilmonkey
Umm, I would save your hard earned 69 bucks.
Old Aug 11, 2010 | 03:44 PM
VET4LES's Avatar
VET4LES
It is.
Old Aug 11, 2010 | 04:55 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
remember the tornado and turbornator? come on, you know better....don't buy it. just say no.
Old Aug 11, 2010 | 05:15 PM
Tikiman12's Avatar
Tikiman12
all the chip will do is make your throttle response perk up a little and it will feel like you have more power.
Its a trick
Old Aug 11, 2010 | 06:06 PM
MY10GS's Avatar
MY10GS
Remember the Duralub claim?
http://www.consumeraffairs.com/news/dura_lube.htm
Old Aug 11, 2010 | 07:55 PM
slief's Avatar
slief
I would suggest getting a set of muffler bearings instead. They are only $49 and really make a difference!
http://kalecoauto.com/index.php?main...products_id=10
If not the bearings, the dual exhaust "O" pipe beats the heck out of x pipes and its only $99
http://kalecoauto.com/index.php?main...&products_id=2
They are also having a special on blinker fluid! Its a great deal!
http://kalecoauto.com/index.php?main...&products_id=6
Old Aug 12, 2010 | 12:58 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Might need to purchase Kaleco's Butt Dyno to measure those 60 horses accurately. Only $399.
Binford's is cheaper but it's calibrated in Yugos.
Old Aug 12, 2010 | 06:07 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
No! Do NOT buy the GForce chip. The HForce chip is the one you want. It is new for 2011 and produces 6,465 hp and 6,234 ft/lb of torque on squirrel droppings. I've got Photoshop and can produce the dyno results to prove it.
Do you need another hint about what we think of this?
Old Aug 12, 2010 | 07:16 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Truly jacking this off topic, but are we talking about Tim's Binford Tools? Wow, that's now going back a few years....
Old Aug 12, 2010 | 01:43 PM
G b 2 G's Avatar
G b 2 G
Kanooter valves are the way to go.
Old Aug 12, 2010 | 03:41 PM
RPHCRMZ51's Avatar
RPHCRMZ51
Blinker Fluid and it's SOLD OUT
Old Aug 12, 2010 | 03:46 PM
avbump's Avatar
avbump
Default GForce Chip
Hey, I GOT it. ha ha ha
Old Aug 12, 2010 | 03:48 PM
BSE1956's Avatar
BSE1956
If it sounds too good to be true, then it's not true.
If you do buy it, then you might want to get some of these (real product) for your stereo:
Description (Alto-Extremo NeoFlex new)
Introductory offer $799.00 (retail $1099.00)
Are you looking for one of the best and most exclusive absorbers on the market? NeoFlex is both of these. The only magnetic absorber for the optimal set up of your hi-fi device. Its' design is based on the principle of magnetic repulsion. Two extremely powerful neodym magnets hold the weight of the hi-fi device. In this way the NeoFlex absorber separates the device from the floor. Its design and high mass make the NeoFlex an ideal instrument to optimize your high end system. Energy is transferred from the device and destroyed in the absorber. NeoFlex absorbers are equipped with two neodym magnets. As with the Lyd absorber, the device can be disconnected with the upper damper ring and it can be connected without the ring. You can also remove individual rings, since the absorbers always remains balanced.
Each absorber can take on 0.5 – 15 kg (1 - 33 lbs). A set of three absorbers can therefore bear a weight of up to 45kg (99lbs.) and a set off four absorbers can take up to 60 kg (132 lbs) which makes the NeoFlex unique on the entire market.
The NeoFlex is Alto-Extremos' new top-of-the-line product.
Material: Stainless steel body, stainless steel cylinder with damper ring, stainless steel platform, two neodym magnets inside the absorber, adjustable height.
Dimension: approx. 3.07" (78mm) in diameter and 2.36" (60mm) height and weighs about 3.8 lbs (1.72kg) each. Weight capacity 99 lbs a set of three and 132 lbs the set of four.
The NeoFlex is simpply the best vibration control available!
To GForce Chips
