New Racing/Custom Seat Option for C5 and C6
#61
Former Vendor
No, we still need to add the seat conversion above, and the bucket seat that we show is still being updated.
I will try to make a page to explain what is currently being made and what is expected in the near future.
#63
Former Vendor
As far as fiberglass seats go, we had a seat similar to the Pole Position seat made with larger holes. We were happy with it overall but asked to raise the holes even slightly higher. We are having a black leather sample made next. If we are happy with that we will see if the factory has ebony leather available as well.
#65
Former Vendor
Former Vendor
If you'd like to add a sub belt slot to your bottom I recommend buying a new foam pad and shipping it to us or having us get it for you. We can sew the opening in the new bottom cover and add the slot to the foam. You will need to spread the two center suspension wires in your bottom frame outward to make room for the sub belt to pass through.
We can do the C5 or C6 pattern and can use suede for the inserts if desired. We've added the C6 heaters before; haven't tried the C5 but would expect that should't be a problem. If you want to stop sliding around in your stock seat but keep all your power track options and not loose headroom, this is the ticket.
#69
#71
