Which Oil to Use for C6 LS3
#61
[QUOTE=Danno5069;1599518939]I would change oil in boat b4 storage because of possible moisture content. So ive been told will do the same for vette. Its not stored per say as I will start it occassionally and drive it around the block on a dry winter day[/QUOTE
good idea on the moisture... but here in Seattle it rains everyday - so moisture is not a problem you can fix by changing oil.
#62
I also use it in my 26 year old inboard ski boat.
#63
Received 1,136 Likes
That is my oil cap. I bought my 05 10 months ago with 32k on it from a used corvette dealer. It came with a 2 year 50k mile engine and transmission warranty. I was told if I used any oil but Mobil 1 5w-30 the warranty is void.
#64
Received 4,712 Likes
Simple answer...Mobil 1 5w-30, nothing more needed
#67
me to only use premium gas and if I needed work done to be sure the shop was well versed in Corvettes. All seemed like good advice, so I guess my point is while maybe he can't tell me which oil to use to keep the warranty he was really just protecting me in case I was
an idiot.
#68
Mobil has a rebate going on and Pep Boys has one too. If you do both (which is valid), you can get a 5 quart jug for $6. That makes it the best oil.
