Convertible Top Adjustments
09-28-2010, 11:25 AM
Is there a simple fix for the top rubbing on the toneau cover when opening and closing the top?
09-28-2010, 11:37 AM
Top Adjustments
I had to get the dealership to replace the pistons that raise the waterfall cover. After they replaced them, they did not rub again.....SO FAR!!!!
09-28-2010, 11:42 AM
Quote:
Originally Posted by
yn1bennett
that's a great idea!
09-28-2010, 12:07 PM
Cruise-In I Veteran
Cruise-In II Veteran
I had the same rubbing problem , and today the dealrship fixed it under warranty. I believe it was just some adjustments, not replacing anything. There appears to be a bulletin out on this problem.
here is what the repair order said
" 1st bow hitting top latch, Operate top, found first bow hitting tonneau latch, check for bulletins, found 09-08-67-013A Adjust tonneau cover to clear latch assembly. After adjust, operate top several times, OK "
I tested it before I left the dealers lot, and it was OK
09-28-2010, 01:48 PM
Anyone with pics of exactly where this wear is occurring?
09-28-2010, 01:52 PM
Retired & lovin' it!
This is one of the reasons I like the manual top....just one less item to have a problem!
09-28-2010, 01:57 PM
1st bow hitting tonneau is different than 5th bow hitting. 5th bow is the one next to the rear glass, 1st bow is the one that sits on top of the windshield. We need to clarify what we are talking about here...
09-28-2010, 02:01 PM
Dave S
I've read here that this is not a power vs manual issue. It can happen with manual top also.
09-28-2010, 02:18 PM
On my 2010 vert with manual top I must apply upward pressure by hand to the tonneau in order to allow the 1st top bow to clear the tonneau latch.
07-06-2014, 08:37 PM
1st Gear
c6 top hits latch when openeing/ closing. must pull cover back by hamd for it to clea
AlfredMay
I have the same exact problem on my 2010. did you find out how to fix this issue?
07-06-2014, 09:27 PM
got an 08 that may need adjusting so I am watching this thread
07-06-2014, 10:24 PM
drich2905
Me, too! It just started, does once in a while.
07-07-2014, 12:33 AM
I'm betting that you have the passenger seat back all the way. Move it forward about an inch and your problem will be resolved.
07-07-2014, 02:18 AM
Dave S
07-07-2014, 09:29 AM
Torch Ace
I'm willing to try that, but what does the seat position have to do with power top movement or interference?
Thanks.
07-07-2014, 01:13 PM
Had the same problem on my 2013 427 vert. Simple adjustment done at the dealership under warranty.
07-07-2014, 03:38 PM
passinger seat too far back will not let the rear glass go forward enough
07-07-2014, 05:42 PM
E-Josh
Nothing about the C6 convertible top is simple. Take it to the dealer.
07-07-2014, 11:28 PM
cranky
Exactly what Cranky said. Tonneau cover is hitting the bottom of the rear glass when it is in the process of folding or unfolding.
07-08-2014, 09:02 AM
top rubbing the tonneau cover when opening/closing
E-Josh
I noticed this on mine as well. No idea as to how to make adjustments to fix the problem with the mechanism. My "mickeymouse" solution is to reached back to pull the top forward before the tonneau cover closes/opens.
