How do I remove this part? (Air dam)
See the air dam (top piece in the picture, disregard the bottom two piecies)? How do I gain access to the left and right slots of the air dam to get it off? Taking the 3 bolts out of the middle is a sinch but how to get it all off has me perplexed.
You will need to remove the five 7mm screws that fasten the front fascia along the bottom. This will allow you to pull the fascia down at the ends and locate the plastic push pins holding the center section of the air dam in place through the tabs at the ends. Pull the pins out, remove the three 10mm screws along the length of the center section of the dam and then grasp it and rotate it off the support brace and pull it toward the front of the car and it will come off.
Jack up one side, get underneath and see with a flashlight where all the screws are. Take your time removing the ends from the center. The plastic pins are kinda hard to pop out...take your time.
Just look up under the front of the nose, you can't miss 'em. They must be removed in order to pull the fascia down enough at each end to reach in between the fascia and the support that it's fastened to so that you can see the two push pins holding the ends of the air dam and remove them. I used a forked tip pry tool to pull the pins out. You can reuse the plastic push pins. The 7mm screws are quick and easy to remove/replace.
