New!! Two-Tone Leather Console Covers **$109.99**
#321
one more pic
#323
Hope you don't need tech help or follow up if you purchased from Corvettemods. I never could get them to reply to questions I had on a purchase last month.
#324
Same here, the stitching is a bit slanted, but I'm the only one who would notice.
#325
Maybe normal. ?? then... Someone thought stitching across top at slight angle. , mmmmmmmmmm different.
Oh by the way,, these seem to be from the company called,,
Performance Choice.
I tried thier web sight but its under new construction
Performance Choice.
#326
Well, I got the cover on console lid. mmmmmm, easy ? naaa..
After looking, trying, retrying, i think i got it.
I also added diff tape as the one in the kit is ??, well once you stick down its done , so if you have to re adjust then its not very good at holding in position. Here is a few pic's .
After looking at some pic's of cover installed in veh's on line, and reading instructions,, I see that alot of us did not stretch it tight enough and put in correct position.
Big mistake i did was not clean location for tape with alcohol.., and tape pulled up.. Clean it, or it wont stick good.
First pic is showing not pulled enough.
Second picture shows the seam salvage, in position [ now] after pulling into position.
And also tape i used that seems to stick better and hold better.
#328
Console cover on and in car. Luv it. And the slanted stitch lines that run across, seem straight. Must of been fooling my eye's.. before it was in car..
One pic is of old unit..
