Lowering Issues
Old Dec 27, 2010 | 08:31 AM
Chris3's Avatar
Chris3
ok see ya
Old Dec 28, 2010 | 11:42 AM
bonnevillebill's Avatar
bonnevillebill
Keep your head down, man.
Old Dec 28, 2010 | 11:47 AM
OnPoint's Avatar
OnPoint
The Consigliere
I'm with the others - you've got a split in a CV boot. You'll definitely want to get that fixed before you put many miles on it. Otherwise you'll run an axle bearing dry and burn it up.
God Speed in your adventures. Many of us are quite thankful.
Old Dec 28, 2010 | 02:37 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
I don't have experience with the C6 specifically, but in general CV grease is unmistakable - thick, hard to wipe off, and almost impervious to soap and water.
Old Dec 28, 2010 | 04:47 PM
Vivid1's Avatar
Vivid1
Originally Posted by laconiajack
The Corvette as it comes from the factory is a low as the engineers thought practicle. These automotive engineers take into account civil engineering standards, test track results, etc. Anytime you think you know more than these engineers and alter the car's ride height you are setting yourself up for problems.
Also, every state has headlight height laws. Car manufacturers can't go below or above a certain height when designing a car. Look at how much wheel gap most cars in the US have.
Old Dec 28, 2010 | 06:17 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
CV boot is the only place you are going to get that kind of grease on your rim. The grease fittings on the Z51 wouldn't splatter onto your rims if overgreased. A spinning broken CV boot will throw it everywhere.
Old Dec 29, 2010 | 01:05 PM
teenVette's Avatar
teenVette
Veteran: National Guard
Exactly. The car is parked until I get back to the states in April. The cv boot will be the first thing I get looked at when I get back. Thanks everyone for their input.
