** The Official C6 Mega Thread of DIY and FAQ's ..Updated 9/14/16 **
Links to previous stickies....
Power Window Initialize (Resetting the Window Indexing) http://forums.corvetteforum.com/c6-c...-indexing.html
C6 Coupe roof panel noise primer - Long post http://forums.corvetteforum.com/c6-c...long-post.html
C6 FAQ
http://forums.corvetteforum.com/c6-c...questions.html
C6 Tips and Tricks
http://forums.corvetteforum.com/1583388987-post3.html
NO FOBS DETECTED What to do?
http://forums.corvetteforum.com/c6-c...hat-to-do.html
Frequently Asked Questions about the GM Personal Audio Link (PAL)
http://forums.corvetteforum.com/c6-c...-link-pal.html
Using the C6 Navigation system - Parts 1 through 5 and Update
http://forums.corvetteforum.com/c6-c...rough-5-a.html
http://forums.corvetteforum.com/c6-c...l-updates.html
2005 - 2006 Corvettes Recalled
http://forums.corvetteforum.com/c6-c...-recalled.html
Alternate NPP Vacuum Line Routing via Rocker Panelhttp://forums.corvetteforum.com/c6-c...ker-panel.html
Links to Model Year Changes
http://forums.corvetteforum.com/1580332846-post1.html
Number of C6 Models Built per Model Year
https://www.corvetteforum.com/forums...odel-year.html
LS2 Certified Horsepower?—For LS2 guys
http://forums.corvetteforum.com/c6-c...-ls2-guys.html
2012 Corvette Lear Car2U garage door/security gate setup
http://forums.corvetteforum.com/c6-c...ate-setup.html
Swapping out your exterior 'A' pillars - Detailed Instructions with PHOTOS
http://forums.corvetteforum.com/c6-c...th-photos.html
Corvette Forum Acronyms
http://forums.corvetteforum.com/c6-c...-acronyms.html
Corvette C6 Headlight Lens Replacement
https://www.corvetteforum.com/forums...placement.html
Key Fob Battery Replacement DIY
https://www.corvetteforum.com/forums...ement-diy.html
https://www.corvetteforum.com/forums...hat-to-do.html
Clock / Nav Fix
C6 Clock/Nav fix... - CorvetteForum - Chevrolet Corvette Forum Discussion
Fuel Pump/System Part #'s
Fuel Pump/System Part #'s - CorvetteForum - Chevrolet Corvette Forum Discussion
C6 FAQ
C6 Tips and Tricks
Clock / Nav Fix
The following 6 users liked this post by pewter99:
07vetteusa (12-15-2015),
danadeco (08-27-2020),
davidlnf (07-07-2018),
Qshiplover (02-23-2020),
serelaw (07-05-2017),
and 1 others liked this post.
Go to the C6 FAQ link above and it has all the old (highly valuable) links. ....and they keep it updated regularly to boot. Used it just now because my rear hatch switch (the one above the license plate) is dying. Turns out, it's a relatively easy and cheap DIY fix! Thank you (again) CorvetteForum!
Race Car Tech
Race Car Tech
DIY: C6 TRANSPARENT LEXAN TOP REFINNISHING PROJECT.
https://www.corvetteforum.com/forums...finishing.html
Race Car Tech
How to remove watermarks (Photobucket) from thread photos.
in the Help Forum
https://www.corvetteforum.com/forums...post1601418617
in the Help Forum
- I Also owed a c5 (1999 convertible with every option for a convertible). I bought a 2006 C6 3lt convertible this past April. It has only 24k mikes in it.
1) The harmonic balancer delaminated on it = $900 repair at Che y dealer. I think it’s a common problem with c5s and C6s. Take a look at the balancer while the car is running. If it’s wobbling, it needs to be replaced. - the Power convertible top had an issue of one bow hitting the rear window During both up and down motion. Easy fix though, I did it in 1/2 hr today.
- if the car you look at has the nav system. Check to see if the clock is working. If the battery was ever unhooked, there was a glitch in the software that caused the clock to disappear (mine was that way). There’s a fix for it on this forum, but you need a computer that can burn disks OR you can buy a disk with the fix on it via the internet.
- ive only driven it a few hundred miles so far but it rides nicer vs the c5. I had run flats on that car whereas this car has Michelin pilots on it.
that’s all I’ve run into so far. Good luck in your search for a C6.
Only thing I can complain about are the seats are horrible.
I've heard the updated ones in 2012+ are much better but I can tell you I'm not a fan of the seats. My wife finds them uncomfortable enough to complain about them and how we should take the truck
Other than that my trunk release button in the rear of the car has failed 2x and I did have the steering rack replaced along with the EBC but honestly I think the dealership was clueless on this because when it happened again to me someone here on the forum said to try and unplug it and plug it back in. That fixed the issue. Felt like Microsoft had its hands in my car
Link to FREE downloadable Electronic Owner's Manuals
Here's a link to the GM website to download free copies of C6 owners' manuals:
https://my.chevrolet.com/how-to-support
4th Gear
Finally did it--went to upgrade the lights in the sun visors and the plastic insert came loose.
Those of you who have repaired the sun visors, what's the best approach; super glue, 3M tape, replace the whole thing? Searched the forum and couldn't find the answer.
Also, I removed the mirror from the pillar, complete with the bezel. Will I have trouble putting it back into the pillar or should I remove the bezel, install that and then reinstall the visor?
