Rejex...
Old Feb 15, 2011 | 10:01 AM
  #41
lastcowboy's Avatar
lastcowboy
anyone ever use this GLAZE
Old Feb 17, 2011 | 10:46 AM
  #42
LEAVINU's Avatar
LEAVINU
Ok, I'm confused by some comments and processes posted thus far.
The bottle clearly states do NOT apply wax on TOP of Rejex. Verbiage right from the bottle:
"Do not apply waxes or polishes over RejeX, as the abrasives found in these products will remove the RejeX protection."
Sounds to me like many may have been spinning their wheels applying the RejeX then putting wax right on top of it.
My recent detailing process was......
  1. Wash & dry
  2. Clay
  3. Adams swirl & haze (Flex machine)
  4. Adams fine machine polish (Flex machine)
  5. Zaino Z2/Z5 applied simultaneously (by hand)
  6. RejeX (by hand)
*The in between steps above were handled with Zaino Z6 detail spray.
I'm now getting more comments about the shine than I am the cam rocking the car back and forth at idle.
Old Feb 17, 2011 | 10:55 AM
  #43
Hutch45's Avatar
Hutch45
Wounded Warrior Escort '11
You are correct. The instructions are pretty clear.
I have been using ReJex for many years on several different autos.
My process is:
Wash & Dry
Clay Bar
Swirl remover (if needed)
ReJex ( applied by hand, removed with orbital polisher)
  1. Wash & dry
  2. Clay
  6. RejeX (by hand)
Old Feb 17, 2011 | 11:23 AM
  #44
KneeDragr's Avatar
KneeDragr
No.
Why, are trying to hide all your swirls?
Old Feb 17, 2011 | 12:00 PM
  #45
lastcowboy's Avatar
lastcowboy
Originally Posted by KneeDragr
No.
no swirls in my paint never use a buffer.just a free sample.
Old Feb 17, 2011 | 12:05 PM
  #46
wrecks's Avatar
wrecks
I like the stuff. I even use it on my skis and snow shovel to avoid the snow sticking to it
Old Feb 17, 2011 | 12:08 PM
  #47
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
  1. Wash & dry
  2. Clay
  6. RejeX (by hand)
I've never had any issues applying pinnacle wax over Rejex...my rejex lasts just as long with wax on top or not.
I think those instructions are saying don't take an orbital machine and menzerna or other professional polisher and buff on top the Rejex, then it will come off.
Rejex is meant to protect the car paint against all kinds of chemicals and weather.. applying a carnuba like pinnacle on top of Rejex is not going to take it off. Besides, Autogeek has also recommened if you use wax, use it on top of the Rejex, NOT underneath.
Old Feb 17, 2011 | 12:19 PM
  #48
lastcowboy's Avatar
lastcowboy
TOOK IT OVER TO A FRIENDS TO PUT IT ON, WILL POST AFTER PIC'.S
Old Feb 17, 2011 | 01:36 PM
  #49
Dale1990's Avatar
Dale1990
St. Jude Donor '15
I could be wrong but from what I've seen most true waxes do not contain significant abrasives unless they are marketed as "cleaner" or swirl remover waxes.
Old Feb 17, 2011 | 01:55 PM
  #50
LEAVINU's Avatar
LEAVINU
Just follow the directions and I think you will be very happy with it.
If we look at this black & white Frank, the bottle makes no mention of how the wax is applied. It simply states, do not put wax over RejeX(their product). So you're not following the directions as you suggested to do so above.
In detailing, I think it's definitely a "to each their own" approach. The process I outlined gave me a an amazing shine with 50k miles on the odometer. The pics you posted look amazing so it definitely seems to be working for you doing it your way.
You could be right; I'm no detail expert by any means.
Old Feb 17, 2011 | 02:48 PM
  #51
lastcowboy's Avatar
lastcowboy
so BEFORE i put this on ,you can not aply wax later ?does the shine from rejix last that long that you dont need wax ? why not just wax the car ?
Old Feb 17, 2011 | 04:08 PM
  #52
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
To each his own So long as you are happy wiht the results. I was following the advice of Autogeek. THe Carnuba wax from pinnacle does not have any abrasives or cleaning agents, so it won;t hurt the rejex.
Old Feb 17, 2011 | 04:10 PM
  #53
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
The Rejex is a Sealant, and will bond with the paint..it will last ALOT longer than regular wax. I am not detail expert either, just learned by reading about it.
Try it both ways and see what you like. I tend to agree, Rejex is amazing and leaves a great Shine, but more of a shine than a "wet" look so I top it off with wax to help deepen it... that is simply according to my eyes. Plenty of people just use Rejex and are happy with that too.
Either way is not going to hurt your paint.
Old Feb 17, 2011 | 04:22 PM
  #54
Dif's Avatar
Dif
Rejex is a Sealant.
It doesn't take out swirls etc or Prep the paint.
It's meant to go on after the paint has been made free of swirls etc.
If there is anything between Rejex and the paint, then the Rejex will only last as long as what it's covering.
As FrankTank mentioned: some like to use wax Over the Rejex for a less plastic look or deeper richer shine.
Old Feb 17, 2011 | 04:55 PM
  #55
KneeDragr's Avatar
KneeDragr
All glaze does is fill in swirls. Some contain polishes as well, but the main idea behind a glaze is to hide imperfections in the paint.
Old Feb 17, 2011 | 06:01 PM
  #56
Brian2010's Avatar
Brian2010
After the rejex has cured you can apply a pure carnuba or other waxes on top. It must cure and you must use a plain wax with no cleaner or abrasives in it. ie fuzion there are more I can't think off the top. You get the idea.
Old Feb 17, 2011 | 06:09 PM
  #57
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
just messin wit yall...........
To Rejex...
Old Feb 17, 2011 | 09:10 PM
  #58
BSE1956's Avatar
BSE1956
I'm actually doing a longevity test on my 2 daily drivers:
An Expedition and a Jetta. The Jetta got Rejex and the truck the Zaino, both in November.
Both have been out in a particularly harsh NY winter (except for a few days for the Jetta in the garage). I'll do a good wash and cleanup in the next few weeks to see how they compare.
Old Feb 17, 2011 | 09:37 PM
  #59
Cybernetic Medic's Avatar
Cybernetic Medic
Rejex is a sealant that goes on bare paint which has already had any needed polishing to remove swirls and scratches. Rejex will not remove or hide any imperfections. It is very durable and slick which makes it easy to clean off bird poop and bugs etc. Some detailing aficionados say the shine from a sealant is "plastic looking" and adding a couple layers of carnuba wax gives it a more traditional deep, soft etc. luster. Another great thing about Rejex and other sealants it that it's great on the whole car, i.e. glass, chrome, plastic, and it won't get chalky on rubber trim.
Old Feb 17, 2011 | 10:10 PM
  #60
aseipos's Avatar
aseipos
Rejex is all I use now. Maybe an occasional Meguiar's Detailing Spray on top after the weekly wash.
I could probably find a more time consuming and complicated way to maintain the car's finish, but why?
