Broken Glove Box handle
Just wondering if anyone has any tips on how to get the glove box opened. The handle broke off on Friday and I have not had a chance to look at it yet. I did call the dealer and they ordered one for me and it came in yesterday.
There is a metal piece that shows after the break. Grab it with needlenose pliers and pull it to open the box. I can't remember which end of it, but pull on one end or the other rather than right in the middle. Then on the inside, there are two TORX screws which will allow the entire latch mechanism to fall out. Its a 5 minute R&R. Be sure to save the lock cylinder from the broken latch to transfer over to the new one...expensive otherwise.
What is painful is removing the lock tumbler and reinstalling in the new latch mechanism. Hopefully the earlier posted instructions will work better than my trial & error method which I can't describe here.
[QUOTE=GOLD72;1576805950]With the outer broken plastic beauty latch no longer in place, you will see an L shape shiny metal piece on the right side of the remaining latch mechanism. Take a pair of pliers and grab the bottom of the L piece and pull outward while using your other hand to gently pull open the door. /QUOTE]
This seems to be an ongoing problem.
[QUOTE=ben dover;1576806007]
Maybe bad chemistry for a batch of those plastic latch pieces. Too brittle during cold weather.
Premium Supporting Vendor
What I don't understand is that it seems as if it is all one color. We sell a ton more of cashmere than we do any other color. Also, we sell a lot of Hummer parts and on the H3's we sell the cashmere 3 times per day, but not ebony/black??
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Carbon black is a reinforcing ingredient in rubber, perhaps they use it in plastics as well, but being black have to leave it out on cashmere colored latches, hence their not as strong.
Thanks for the info. gonna go out see if I can get it opened. Glad to hear I'm not the only one having this problem, but sad to see it looks like another of GM's lack of attention to detail.
You can adjust the lid by installing washers under the latch assembly. This moves the latch farther from the door and therefor sets the door closer to the dash. Worked for me. There is no other adjustment.
Received 2,882 Likes
My chasmere latch broke 2 weeks ago. Ordered a black one (cheaper than cashmere) and had it sent to TKO for carbon fiber to match the other pieces of my interior. Hope this ends this problem.
my 08 titanium broke twice. the second time i just left it broke. if you take your index finger, from the drives side it's easier, slide it in behind where the old latch was and you can feel the above mentioned metal latch and just flip it out like you would pull the latch. pops right open and i figured i could open it and nobody else could so i liked it broke ok...
