How do I know if it has the Z51 package
Old 02-19-2011, 09:47 PM
Saint Rick
Saint Rick's Avatar
Default How do I know if it has the Z51 package
Hello all. I'm new to the forum and am about to be new to corvette ownership. I'm starting to look at used vettes and don't know how to tell whether the car are equipped with the Z51 package or not. Is there a way to tell for a novice like me?
I got the VIN number for a car I will look at tomorrow and put it into compnine. It appears to be accurate on colors, external, interior, top, etc. It said it had the Z51 package but it alos said it was 1 of 1 and thats hard to believe, I've seen other posters indicate the site may not be accurate. Any help would be appreciated.
Rick
Old 02-19-2011, 09:48 PM
LTC Z06
Get Some!
Support Corvetteforum!
LTC Z06's Avatar
Open glove box, read white sticker, look for Z51 on sticker.
Old 02-19-2011, 10:23 PM
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Along with all the other RPO codes for options and/or features the car has. A few folks had a hard time finding that white sticker, but it's on the inside of the door, usually on the extreme left side of the door.
Old 02-19-2011, 10:36 PM
RicK T
RicK T's Avatar
Here's a pic of one. Note the middle of the bottom line is "Z51".
The codes are listed alphabetically.
http://forums.corvetteforum.com/1575110657-post1.html
John Sog (04-20-2019)
Old 02-19-2011, 10:56 PM
cclive
cclive's Avatar
Yup!
Old 02-19-2011, 11:13 PM
cmonkey713
cmonkey713's Avatar
Received 1,237 Likes on 908 Posts
Easy, if your brake rotors have little holes in them you have Z-51 option.
I guess it would be possible that the previous owner changed the rotors to an aftermarket but not too likely.
Old 02-19-2011, 11:33 PM
Saint Rick
Saint Rick's Avatar
Awesome....thanks everyone
Old 02-19-2011, 11:44 PM
Mike's LS3
Mike's LS3's Avatar
Or F55 option. Look on the inside glove compartment door for the RPO code Z51 as described in the above posts.
Old 02-19-2011, 11:59 PM
LTC Z06
Get Some!
LTC Z06's Avatar
The best way to tell if it's a Z51 is to just feel the awesomeness coming off the Vette.
Old 02-20-2011, 12:00 AM
Vette_DD
Vette_DD's Avatar
Not if it's an 07 with the F55 option. Cross-drilled brake rotors now included with F55 Magnetic Selective Ride Control on the 07s.
Old 02-20-2011, 04:20 AM
CO Lightfoot
CO Lightfoot's Avatar
RPO code lists: http://www.digitalcorvettes.com/foru...ad.php?t=88957
Old 02-20-2011, 06:58 AM
SeanMo
SeanMo's Avatar
St. Jude Donor '10-'11
If it makes a loud squeaking noise from the rear, it's probably a Z51
rudutch (03-05-2018)
Old 02-20-2011, 08:27 AM
anotherone
anotherone's Avatar
with 55000mi mine doesnt have a loud squeaking. Why would someone not correct this?????????????
Old 02-20-2011, 10:28 AM
markmott
markmott's Avatar
St. Jude Donor '16
Mine doesnt squeake, should I take it to the dealer to have it checked. How much do they charge to put the squeake in? After I dust my buddies F55 through the twisties here in the mountains I will take it in.
Old 02-20-2011, 01:41 PM
08vycpe
08vycpe's Avatar
Most Z51's have grease fittings at the outboard end of the rear tie rods right next to the inside of the brake rotor. A lot of "oil changers" don't know they are there. Maybe you need to lube the bushings.
Old 02-20-2011, 02:30 PM
sdurg24
sdurg24's Avatar
But you have a Z51, right? I have an 08 coupe with Z51 and 17,000 miles with zero problems and certainly no noise from the rear or into the shop it would go. Should I be aware of something?
Old 02-20-2011, 04:44 PM
c6_rob
c6_rob's Avatar
feel it every day
To How do I know if it has the Z51 package
Old 02-20-2011, 07:59 PM
SeanMo
SeanMo's Avatar
Bushings have been lubed, starting to think it's the sway.
Old 02-20-2011, 08:06 PM
KenHorse
KenHorse's Avatar
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,400 Likes on 1,365 Posts
St. Jude Donor '11-'12-'13, '16-'17-'18
And all this time, I thought the way to tell if you had the Z51 option was if you had one of these:
Old 02-20-2011, 08:14 PM
vettedoogie
vettedoogie's Avatar
The squeaking comes only with the customer-applied badges.
Quick Reply: How do I know if it has the Z51 package
